Misfire
Discussion in '1st Gen Tundras (2000-2006)' started by Knob9, Jan 30, 2024.
  1. Jan 30, 2024 at 6:58 AM
    Knob9
    Knob9 [OP] New Member
    2004 Tundra dc limited.
    Just installed a timing belt / water pump kit in my 04 tundra 4.7. Now it has a rough low RPM idle but runs good all out. Checked the codes and it shows 0300 302 304-306-308. It actually shows 2,4,68 twice for a total of 9 codes. I know the marks on the belt and the two of them cams lined up but the lower cam I am not too sure of. Is there anything else that could be going on besides the timing belt being installed wrong that I could check before I tear it down again? Any help would be appreciated.
  2. Jan 30, 2024 at 7:06 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Coil packs and plugs
  3. Jan 30, 2024 at 7:47 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Crankshaft position sensor. Unfortunately you need to tear it down. Sounds like the crankshaft might have been off the marks. I wouldn't go replacing anything else until you're 100% sure it's timed correctly.
    The Black Mamba likes this.
  4. Jan 30, 2024 at 8:25 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    ^^^ THIS ^^^
  5. Jan 30, 2024 at 8:40 AM
    Agree ^^
    Don't get me wrong, the plugs idea is also good, but given the recent belt replacement, I think you probably were off a tooth on timing and you need to resolve that situation ASAP before you go driving it around. It won't be the coil packs, it's rare for a single pack to go wrong, if you're getting multi-misfire, it's not gonna be the coil packs.
    Confirm the timing is good. Re-check. And make sure the crankshaft position sensor wire got routed behind the water pump properly so it doesn't get rubbed through by a belt/pulley.
    When you replaced the timing belt, did you also replace the tensioner and water pump?
    ATBAV8[QUOTED] likes this.
  6. Jan 30, 2024 at 4:57 PM
    Knob9
    I did replace the water pump and tensioner. I have started tearing it down. I am sure that I did not get everything lined up correctly. So what I need to know now is, what needs to be torn down to be able to get to the timing belt? All info I can find involves the water pump replacement. And once i do get to reinstalling the timing belt, how do i get everything in the correct place?
  7. Jan 30, 2024 at 5:23 PM
    ATBAV8
    Tempe, AZ
    Sooooo... Did you or did you not do the timing belt replacement? Asking what needs to be torn down seems odd. If you did it once, you should know. There's no short cuts. Anyway, the short answer is you've got to take the timing belt off to reset the crankshaft and the camshafts. Try this thread out: https://www.tundras.com/threads/anybody-personally-done-a-timing-belt-replacement.75007/. Also, remember that the search function on this forum is your friend.
    shifty` likes this.
  8. Jan 30, 2024 at 5:27 PM
    FishNinja
    Lee
    06DC2wd
    No short cuts bud. There’s one way and one way only.
  9. Jan 30, 2024 at 5:29 PM
    ATBAV8
    Tempe, AZ
    Yes. I know. I assume you meant that for the OP?
  10. Jan 30, 2024 at 6:12 PM
    FishNinja
    Lee
    06DC2wd
    Oh shit sorry lol
