Misfire Problems
Discussion in '1st Gen Tundras (2000-2006)' started by badmagik7450, Feb 27, 2018.
  1. Feb 27, 2018 at 6:18 AM
    badmagik7450
    badmagik7450 [OP] New Member
    2004 Tundra White
    I have 2004 4.7 V8 Tundra and it has started misfiring with the CEL on. The truck will run fine for usually 10-15 minutes then begin misfiring and will shut off at idle. I had the codes checked which showed that three coils were bad. I had the spark plugs and the three coils replaced. The misfiring still continued with the CEL on. After I had the CEL codes checked again, it showed that one of the same coils was bad along with two new coils. I also replaced the engine control module computer, but this didn't change anything either. Does anybody have any suggestions of what it might be? I am running out of leads.
    Thanks in advance.
  2. Feb 27, 2018 at 6:23 AM
    Wires to coils?
  3. Feb 27, 2018 at 7:00 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Overlay to the coil
  4. Feb 27, 2018 at 9:13 AM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Check your injectors.
  5. Feb 27, 2018 at 9:43 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Get the fuel pressure tested also.
    mudslinger79 likes this.
