Misfire on 8 Cylinders! '08 5.7
Discussion in '2nd Gen Tundras (2007-2013)' started by Xolude, Feb 23, 2022.
  1. Feb 23, 2022 at 12:16 PM
    Xolude
    Xolude [OP] New Member
    Liam
    2008 Blue DCSB SR5 Offroad
    33s, 3" lift
    I bought this truck not too long ago, and after driving it for a while, I keep getting misfire codes for every cylinder (P0300-P0308) once my gas tank is around a half tank or lower. It's not a flex fuel truck, and I've replaced spark plugs and coil packs, but I keep getting a code even though the truck runs and drives very smooth. I get no hesitation on throttle, but I'm suspecting fueling- maybe a fuel pressure regulator? All help is greatly appreciated.
  2. Feb 24, 2022 at 12:13 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Hi,
    I see that this is your fourth time posting this. I hope someone has some input but I haven’t seen this come up as a common problem. Have you tried replacing the intake manifold gaskets.?
  3. Feb 24, 2022 at 12:26 PM
    808Tunderer
    808Tunderer New Member
    2021 DubCab SR5 4x4 TRD Offroad
    Stock
    definitely check for intake/vacuum leaks.
