Misfire no codes
Discussion in '2nd Gen Tundras (2007-2013)' started by Bassfishinfool, Oct 27, 2024.
  1. Oct 27, 2024 at 7:54 PM
    Bassfishinfool
    Bassfishinfool [OP] New Member
    Michael
    2007 silver tundra trd offroad
    I am getting misfire when I am idling In drive and reverse
    Only get it a few times in park. When I am driving at 70 and drop my acceleration then pick it back up as soon. As it hits 1800 1900 rpms it starts misfiring alot then goes away when stomp on the gas. I am at a loss with no codes being thrown
  2. Oct 27, 2024 at 8:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Do you have a scanner to see what your fuel trims are? What bank and cylinders are involved? Could be bad coolant sensor, vacuum leak, plugs...
  3. Oct 27, 2024 at 8:34 PM
    Bassfishinfool
    Michael
    No I do not I will have it hopefully scanned on Tuesday don't have access to a fancy scan tool. Only the free one at auto zone hahaha
    Mdl likes this.
  4. Oct 27, 2024 at 8:35 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Probably spark plugs. Check all of them.
    Mdl likes this.
  5. Oct 27, 2024 at 8:36 PM
    Bassfishinfool
    Michael
    I changed the cam shaft sensor , pcv valve , all the spark plugs , 1 coil pack that was failing on number 8 . Still no codes and running terrible cleaned the mass air flow and throttle body . I ordered a fuel pump due to the gas gauge has been not correct for a long time. Running out of ideas
    Mdl likes this.
  6. Oct 27, 2024 at 8:39 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Did you buy the plugs and coil from a reputable source. I got bad plugs off Amazon once. Even though they are pre gapped,always double check.
  7. Oct 27, 2024 at 8:46 PM
    blackdemon_tt
    Check the ground at the battery. Make sure that bolt on the fender is tight.
    Mdl likes this.
  8. Oct 27, 2024 at 9:34 PM
    Bassfishinfool
    Michael
    I bought denso iridium from oriellys. I will double check the ground connection. It all happend at total random I drove it towing the boat ran like a champ went to work for a week the drove 1 hour in bumper to bumper gridlock traffic and as soon as I was able to get on the gas and start moving it craps out and start sputtering and motor shaking thought I was running out of gas but still had plenty filled it up and had that problem ever since
  9. Oct 28, 2024 at 3:39 AM
    blackdemon_tt
    How old is the coolant?
  10. Oct 28, 2024 at 7:08 AM
    Bassfishinfool
    Michael
    Coolant is probably 1 yr, I do have 348,000 miles but has been strong, pulls boat no problem pulls toy hauler no problem . I do have a oil leak I think is coming from crank seal I have oil on the rack and pinion and going down the sides of the heads . Not enough to cause a puddle or massive loss
  11. Oct 28, 2024 at 7:08 AM
    Bassfishinfool
    Michael
    But it's been running fine with the leak for awhile now
