Mirror wiring
Discussion in '2.5 Gen Tundras (2014-2021)' started by Louis, Oct 2, 2020.
  1. Oct 2, 2020 at 6:32 PM
    Louis
    Louis [OP] New Member
    Louis
    Tundra
    light bar tow mirrora
    I bought after market tow mirrors for my 2018 tundra it was supposed to be plug and play all the functions work except my blind spot monitors and my rear traffic sensors does anyone know why?
  2. Oct 2, 2020 at 8:11 PM
    RobertD
    Robert
    DFW, Texas
    Louis, search for the specific brand of mirrors you bought in the search bar. You will probably have to change the order of some of the pins in the connector, not difficult to do. Trick is finding where they have to go. Some manufacturers put them in different orders so you have to compare the pin maps and correct accordingly
  3. Oct 2, 2020 at 8:23 PM
    Louis
    Louis
    Tundra
    I tried looking them up couldnt find anything I do know I'm missing pin 5 on the mirror side which should be a common ground which is also a shared ground with the blind spot monitors just not sure if i tapped into another ground and ran it to pin 5 on the truck side if that would help or not
  4. Oct 2, 2020 at 8:29 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I swapped pins 9 and 18 around and it got my bsm working now.
  5. Oct 2, 2020 at 8:33 PM
    Louis
    Louis
    Tundra
    Did you swap them on the truck side or the mirror side bc i tried swapping 9 and 18 on the mirror side and it didn't work
  6. Oct 2, 2020 at 8:35 PM
    Sumo91
    TN
    I swapped them on the truck side
  7. Oct 2, 2020 at 9:01 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
    Louis[OP] likes this.
  8. Oct 2, 2020 at 9:14 PM
    Louis
    Louis
    Tundra
    Okay thanks ill try it on the truck side
