Mirror question
Discussion in 'General Tundra Discussion' started by scratchex, Feb 24, 2015.
  1. Feb 24, 2015 at 5:31 PM
    scratchex
    scratchex [OP] New Member
    2015 Tundra Limited
    3" lift TRD Exhaust 20" Fuel Lethal Wheels Toyo AT Tires Black Flares w/ spikes
    Not sure if this has already been asked/discussed. So I was initially thinking of getting the black tow mirrors because I really would like to have the blinkers on the mirrors. The only thing that I don't like about the tow mirrors vs. the ones I have now is the size. I really don't care for the larger size tow mirrors and was hoping that I could get the mirrors I have now but w/ blinkers but that's not an option.
    Just curious (and I think I may already know the answer) but would the mirrors that you can get on the 2015 Taco's work w/ a 2015 Tundra? My guess would be no since the base is smaller?
    Here's a pic of one w/ the style of mirror (w/ blinkers) that I like & would like to install.
  2. Feb 24, 2015 at 5:41 PM
    Mike Tread lightly.
    south carolina
    IF you get the two halfs apart base and and mirror assembly, they should be pretty close in diameter to match up... I dont think toyota pressed those two halfs together...
    something like this http://www.1aauto.com/2014-15-toyot...IEY6K-7XlfXFB51Ns6PTGjChSmuH2d5mgIaAgJw8P8HAQ
    i will keep searching this is one
    http://www.carid.com/spec-d/black-h...EGAHKXb_j0-m_McfIKl44dnrQ3OOxIgHuQaAn7l8P8HAQ... opps not your year but close to your like?
    aftermarket is hit or miss on toyota..
    Or bring out the dremel tool and do some custom work... :thumbsup:
    scratchex[OP] likes this.
  3. Feb 25, 2015 at 3:51 AM
    scratchex
    2015 Tundra Limited
    Thanks for the research. I thought it was odd that the Tundra's only had the 1 option of Tow Mirrors in order to have the blinker function on the mirror.
