Mirror Power Confirmation.
Discussion in '2.5 Gen Tundras (2014-2021)' started by 4Runner, Jan 13, 2018.
  1. Jan 13, 2018 at 2:32 PM
    4Runner
    4Runner [OP] New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    2017. Reading the light blue is the power and the white/Black is ground. Want to tap in to power a radar detector. Thanks in advance
  2. Jan 13, 2018 at 3:42 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Ebay
  3. Jan 13, 2018 at 3:43 PM
    4Runner
    Columbia, SC
    Appreciate the link but I have the connection. Just trying to confirm the wires.
  4. Jan 13, 2018 at 3:45 PM
    poheller
    Scot
    2018 platinum
    Ok, I used a ground light prob key on key off until I figured the wires out. Not sure what colors as I did it several months ago.
    Les7311 likes this.
  5. Jan 13, 2018 at 5:38 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    according to the wiring diagram you have the correct wires
    4Runner[OP] likes this.
  6. Jan 13, 2018 at 5:42 PM
    4Runner
    Columbia, SC
    Thanks.
  7. Jan 14, 2018 at 11:13 AM
    4Runner
    Columbia, SC
    Did you have hard time getting the tap in the connector? My kit came with multiple sizes and the big ones seem too big and the smaller ones fall out. Thought this was going to be easy.
  8. Jan 14, 2018 at 11:15 AM
    poheller
    Scot
    2018 platinum
    Lol me too. Yes just have to take the small one and take you time working it in. I did mine in 90 degree heat with sweat running everywhere...
  9. Jan 14, 2018 at 12:05 PM
    4Runner
    Columbia, SC
    I’m also considering using a wire tap instead. I’ll keep working on it.
  10. Jan 21, 2018 at 1:13 PM
    4Runner
    Columbia, SC
    Just a double confirmation on this as I just successfully installed the mirror tap. Light blue is switched power and white/Black is ground. 2017 Limited. Hope this helps someone down the road.
    yodanadane, Aj_sat and Les7311 like this.
  11. Apr 13, 2019 at 12:01 PM
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    I have a 2018 1794 and I used the red and the white/black wire for my wire tap. Had no light blue. I guess they changed it up. Just finished the install on a Uniden R3 with a Blendmount.
    ToyTRD21 and yodanadane like this.
  12. Jun 23, 2019 at 6:25 PM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    2019 TRD Sport CM: red and the white/black
  13. Nov 12, 2020 at 2:56 PM
    yodanadane
    yodanadane New Member
    I am guessing Red is positive wire ?
    Thanks
  14. Dec 28, 2020 at 2:19 PM
    greggm
    greggm New Member
    Gregg
    Los Gatos, CA
    2019 CM TRD 4x4
    I just did this to my 2019 CM today and I had RED wire for positive, and a black with white for ground, no light blue at all. In looking at the OP's picture, it looks like the power tap occurred before the mirror whereas I removed the plug and tapped from behind the mirror itself. Maybe that explains the different colors. Oh well its working :notsure:
    yodanadane likes this.
  15. Jul 8, 2021 at 2:48 PM
    MikeyRedFL
    MikeyRedFL New Member
    SWFL
    2021 Limited Crew Max 4x4
    ToyTRD21 likes this.
  16. Jul 13, 2021 at 12:17 PM
    ToyTRD21
    ToyTRD21 New Member
    2021 Wht TRD PRO
