Mirror mirror....
Discussion in '1st Gen Tundras (2000-2006)' started by Rolodetective, Jul 24, 2015.
  1. Jul 24, 2015 at 5:13 AM
    Rolodetective
    Rolodetective [OP] Member
    Vale of Paradise, Indiana
    2004 Black AC TRD
    2004 access cab....so I've got the common loose, rattling side mirror issue. Passenger mirror only. So I did some reading on the intertubes and found a ton of posts repeating the problem and the solution suggesting tightening the screws UNDER the exterior of the mirror.
    Well after extensive observation of the problem, it is not the screws under the mirror. It seems there are 3-4 small screws inside the mirror housing, behind the glass, that essentially secures the two halves together. The black "back" half that is around the glass, and the chrome "front" half that faces toward the front of the vehicle.
    Well it looks like I'm missing a few of those screws. Removing the mirror glass does not seem to be a fix as the motor and other structural masses inside appear to completely block access. Picture a substructure under the mirror essentially the same same size and dimension as the glass itself.
    So, I'm really hoping someone has found a solution. This is driving me crazy!!
  2. Dec 31, 2023 at 11:33 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Hope he figured it out. Almost 9 years later...
    Jack McCarthy and shifty` like this.
  3. Dec 31, 2023 at 1:33 PM
    There's another thread on here that covers exactly what needs to be done.
    Jack McCarthy likes this.
  4. Dec 31, 2023 at 9:25 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  5. Dec 31, 2023 at 9:27 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I had to check to make sure this wasn’t the same member
  6. Dec 31, 2023 at 9:56 PM
    I’m pretty sure I warned the rb55 guy. I think he admitted early on he was only here to make the 30d/50post mark so he could list his truck or something.
  7. Dec 31, 2023 at 9:58 PM
    The Black Mamba likes this.
  8. Dec 31, 2023 at 9:59 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    shifty`[QUOTED] likes this.
