Mirror Cap Removal
Discussion in '1st Gen Tundras (2000-2006)' started by MSCRUGGS61, Feb 17, 2019.
  1. Feb 17, 2019 at 2:33 PM
    MSCRUGGS61
    MSCRUGGS61 [OP] New Member
    2002 Tundra 4x4 Limited TRD
    Anyone know how to remove the mirror caps on a Gen 1 (without breaking anything)?
  2. Feb 17, 2019 at 6:19 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
  3. Nov 11, 2019 at 10:25 AM
    Slider2012
    Slider2012 New Member
    2003 Tundra Access Cab
    CHERRY
    How’d this go? I’d like to do it soon. Looks like there’s six tabs. Four easy ones, two hard to get to. Did you get it done?
  4. Nov 11, 2019 at 11:25 AM
    Professional Hand Model
    Hand Protectors
    I successfully removed one cap without breaking any tabs and only broke one tab on the other. The tab which broke is inaccessible. All the other tabs need to be disengaged prior and this inaccessible one left for last as the cap is manipulated at an angle out of the tab hole. A curved hook blade was used for the other hard to reach one.
    I removed the mirror face to access and see the tabs.
    Used flat screw driver to push the tabs one at a time and then wedged AS I WENT ALONG a popsicle stick between the main assy body and the cover. This holds a slight tension on the cover and also keeps the cover from reengaging back into the slots I gained ground on. You could make some hard cardboard wedges in lieu of the sticks.
    I took ‘how to’ pics and posted them here somewhere last year on this, but its buried. Start with the easy ones. Insert your wedges and cherry pick the easier tabs until the inaccessible one is left for last. If it breaks, just use a small dab of adhesive to hold on reinstall where the tab is no longer.
    I used 1D6 lacquer color match and clear coat.
    G_unit3000 likes this.
  5. Nov 11, 2019 at 11:48 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    It's not easy without breaking any tabs. I broke one tab per side on mine.
  6. Nov 11, 2019 at 12:56 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  7. Nov 11, 2019 at 1:58 PM
    Hand Protectors
    You are the man for this find!
    Another note: One of these mirror caps (an entire assy) may be aftermarket as years ago some goofy guy backed into my side view. Insurance paid for a new one and its one of those ‘objects appear smaller types’. Shoulda rejected it!
    TX-TRD1stGEN likes this.
