Mirror Cap Popping Off?
Discussion in '2.5 Gen Tundras (2014-2021)' started by AlaskanAssassin, Jul 21, 2021.
  1. Jul 21, 2021 at 8:32 AM
    AlaskanAssassin
    AlaskanAssassin [OP] I now walk into the wild
    David
    Alaska
    2020 DC TRD-OR, Cement
    34508BE8-14C2-463A-BDA2-68D56575F45C.jpg Am I the only one that has an issue with my OEM mirror cap popping off track? It’s only the driver side but no matter what I do to try and pop it back in, it continually unseats when going over rough terrain. It hasn’t become a major issue yet but I fear it will fly completely off one day….and my OCD kicks in every time I look into my side view mirror.
  2. Jul 21, 2021 at 8:40 AM
    Taco-Spike
    Two Trucks
    Never had an issue unless I take it off. Even taking it off half a dozen times, still holds strong. EDIT (On my Tacoma)
    Might have a busted tab inside it. Since it's easy to come off might want to check inside
    AlaskanAssassin[OP] likes this.
  3. Jul 22, 2021 at 3:44 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
  4. Jul 22, 2021 at 4:54 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Since your truck is a 2020 wouldn't that be covered under warranty?
  5. Jul 22, 2021 at 5:53 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Probably a broken or misaligned tab. Pop it off and look for one that’s a little cock eyed and missing its slot putting a bit of tension in that area. Carefully realign it and snap everything back together.
  6. Jul 22, 2021 at 8:29 AM
    AlaskanAssassin
    David
    Alaska
    That’s a good point. Didn’t think about that.
  7. Jul 22, 2021 at 6:53 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Mine will not stay in place, all tabs are good. I just pop it back in every once in a while.
  8. Jul 22, 2021 at 7:20 PM
    Elduder
    Elduder New Member
    I replaced mine with painted ones, DS stays on fine, PS does the same as OPs. Sometimes it takes a week other times a couple days. Tabs are actually broken on the DS and its fine, yet all the tabs are good on the PS. I think its just a manufacturing defect since the area that pops out is just a beveled edge and has no clip. I plan to order a replacement to see if its a one off issue.
    Rob's Inferno likes this.
  9. Jul 22, 2021 at 9:35 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Same as @Elduder, I replaced my chrome caps with painted OEMs.
    My PS does the same thing, maybe not to the extreme your's is in the picture.
    I just give it a palm smack every now and then and it pops back into place.
    I guess I'm just too lazy to actually pull it off and see if it can be fixed.
    Elduder and AlaskanAssassin[OP] like this.
  10. Jul 23, 2021 at 4:52 AM
    Medinasmoke
    Medinasmoke New Member
    hugh
    Ohio
    2020 black crew max
    Went thru same thing . Can’t remember if it sequence when installing [top or bottom first]or one last squeezed that locked it in
  11. Jul 23, 2021 at 5:06 AM
    Dan_Gleesac14
    Dan_Gleesac14 New Member
    2023 Tundra SR5;2018 Tundra Platinum (SOLD)
    Means you're not going fast enough :) jk but yea as others have mentioned, I would pop it off, check and make sure tabs are all pointed straight, and pop back on properly. should be like a 5 min process if that per side.
  12. Jul 23, 2021 at 5:49 AM
    War Machine
    War Machine SSEM # 5 3MW
    It’s not snapped all the way in. Just keep pressing until you get it locked in right. It feels like it’s snapped in, but there’s always one more “click” you have to get.
    Hightide and Medinasmoke like this.
  13. Jul 23, 2021 at 6:31 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    I replaced my chrome ones with colour matched and I easily found a few short videos on Youtube (one by Sparks) on how to pop them off and on without hopefully busting any tabs. Might be good to take a quick look before prying it off for a look. Disregard if you're super capable, I'm not.
  14. Jul 23, 2021 at 6:39 AM
    War Machine
    First one I did was a PITA. Now I’ve got it down pretty good and can do it in just a few seconds.
