Mirror Cap Fitment
Discussion in '2.5 Gen Tundras (2014-2021)' started by cantle, Feb 5, 2019.
  1. Feb 5, 2019 at 7:23 AM
    cantle
    cantle [OP] New Member
    Durango, CO
    2018 Platinum CrewMax Barcelona Red
    TRD Pro Exhaust, TRD Skidplate, TRD Faux-Pro wheels, Ridge Grapplers
    Hi All,
    Has anyone had any issues with the fitment of secondary (color-matched) mirror caps? Specifically, the clips not registering in their respective spots?
    I purchased a set of matched caps from Sparks Parts when I first got the truck. The original caps came off easy, and I re-installed them to get the method down. Then when trying to put the "new" ones on, it was a bear. They seemed to just flex and never go in place.
    I finally got them to go on, after a careful amount of struggling, but the passenger side keeps popping off. I push it back into place, and a day later it's out again.... Just enough to bug the shit out of you as you look at it.
    Any ideas on how to mitigate this? Has anyone dealt with a bad run of these mirror caps?
    Last picture is the driver side, as it sits. Seems normal to me.
  2. Feb 5, 2019 at 7:28 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I kinda had something like that happen when installing some mirror caps. One of the clips broke and it would sometimes “pop” off. DO you have a busted clip on the pass side?
  3. Feb 5, 2019 at 7:40 AM
    cantle
    Durango, CO
    I haven't looked, but nothing seemed to break/snap/pop when I installed.
  4. Feb 5, 2019 at 7:42 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Neither did mine pop break snap. I just pushed a little too hard before making sure all the clips were lined up and the clips “bent”. Just food for thought... good luck.
    If there are no broken clips I’d contact wherever you got them from and ask for a replacement.
  5. Feb 5, 2019 at 7:58 AM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Got mine from sparks as well and the fitment isn’t like factory either.
    Rocko9999 likes this.
  6. Feb 5, 2019 at 8:03 AM
    Michael Tregre
    Michael Tregre New Member
    '14 Tundra SR5 CM
    Notta
    I have the same issue. Only on the inside line though. The outside, or leading edge is fine. They have been on for about 5k miles, never settled or popped off.
    Also bought mine from Sparks. Im sure there is an official way to install them, maybe that would solve the issue.
  7. Feb 5, 2019 at 8:05 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    What about taking a heat gun and massaging them into place after they’re warmed up??
  8. Feb 5, 2019 at 8:08 AM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Mine did this, I smacked the heck out of it and it popped in and has not been a problem since.
  9. Feb 5, 2019 at 8:20 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    LMFAO :rofl::rofl::rofl:
  10. Feb 5, 2019 at 11:57 AM
    terrier72
    terrier72 New Member
    Mine are slightly off also, mine came from Sparks.
  11. Feb 5, 2019 at 6:41 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Same here. I had to bludgeon them pretty solid with the palm of my hand. They popped right in place.
  12. Feb 8, 2019 at 10:03 PM
    Baldmonkey22
    Baldmonkey22 New Member
    Quartz Hill, Ca
    Same on mine, just had to squeeze it in and push harder. Tilt the mirror so you can see where the clips are and try to push only where the clips are, i thought something was wrong but it finally went in.
  13. Feb 8, 2019 at 10:06 PM
    ryanw4x4
    ryanw4x4 New Member
    Ryan
    South West Washigton State.
    2011 SR5 Trd OFF-ROAD
    I had to show more force toward it than i planned. It took a few gentle raps from the palm of my hands then popped into place. First one was a 10 min ordeal, second was a min flat.
  14. Feb 8, 2019 at 10:23 PM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Tried and tried but still not flush. Hasn’t blown off yet so I that’s good :fingerscrossed:
  15. Feb 8, 2019 at 11:01 PM
    Baldmonkey22
    Quartz Hill, Ca
    Like i said theres on clip that isnt in all the way, you'll see it by tilting the mirror.
  16. Feb 8, 2019 at 11:03 PM
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    Mine weren’t sitting flush so I pulled them off and re installed them. The trick is that you have to make sure they are going in at the right angle and kinda “force” them into place. 8707C268-2ECB-4376-B856-844A7CB80BA1.jpg 4FD11829-75BB-463F-B0DE-32344B20BD8E.jpg
    Baldmonkey22 likes this.
  17. Feb 9, 2019 at 10:16 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    Exactly. Mine were doing the same thing and I kept thinking what the hell. Got mad and made a fist and hit it hard and it went in and stayed in. I thought well SOB.
  18. Feb 9, 2019 at 10:57 AM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Oh, mine looks like your second pic.
  19. Feb 9, 2019 at 12:33 PM
    RoujePN
    RoujePN New Member
    2019 Platinum CM 4x4 5.7L 1G3
    @OP FWIW not to knock Sparks, there have been a number of threads on this and door handle topics. Somewhere Micah provides a video which may or may not be helpful. Anyway try to search and review a @T-Rex266 or @Patriot DIY thread. Sorry can't remember exact OP but seem to recall middle way through there are comments on possible clip configuration differences and work around suggests from either of the two mentioned. A bit dated but possible help for your effort I trust and associate methods these guys suggest, but cannot personally confirm b/c
    1) I just purchased mat, mirrors and handles from @Roman and
    2) Since parts still enroute so I haven't attempted change yet. After arrival and our snow melt here, I will go back and manually look up the thread(s) before attempting to change out. GLWYI
    Roman likes this.
  20. Feb 9, 2019 at 6:10 PM
    atl1glf
    atl1glf New Member
    ‘07 SR5 CM, ‘12 SR5 DC Supercharged, ‘19 Limited CM
    Too many TRD parts
    I did the same
  21. Feb 9, 2019 at 6:15 PM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    That's what I did too.. hoped I didn't break anything and went for it
  22. Feb 9, 2019 at 6:20 PM
    TheBeast The Beach
    same here on my gen 2. Driver side is ok but passenger is not as clean. Bought mine from another toyota dealer on ebay.
  23. Feb 9, 2019 at 6:32 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    If it keeps popping out it’s not installed right then.
  24. Feb 10, 2019 at 4:43 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    frayedknot likes this.
  25. Feb 10, 2019 at 4:49 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Cool story bro.
  26. Jan 5, 2023 at 9:21 AM
    mando1369
    mando1369 New Member
    Jose
    17 tundra platinum
    Wish I had looked at this trend before!
    Order mine from sparks also and did the same thing now a small clip broke and now more likely I'm stuck with them, the seem to be a bit larger than the ones on my tundra and also have different part number
  27. Jan 5, 2023 at 9:49 PM
    nohoch
    nohoch New Member
    I also had to push harder then originally thought when swapping out my platinum chrome for white - I had alignment issues and then pushed a little harder and clicked right into place.
    Luckily I avoided broken clips
    bulldog93 likes this.
