Minimum lift to fit 35" tires on my TRD Pro?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Worm, Dec 26, 2015.
  1. Dec 26, 2015 at 7:42 PM
    Worm
    Worm [OP] Worm187
    2015 Trd pro inferno
    ADD honeybadger winch bumper Super winch Rigid light bar Rigid rear bumper LED's 2 10 inch rigid running lights Hazard strobes DECKED Full bed slide out tool boxes Undercover flex bed cover Leer topper Leather seats Air bags 4 inch readylift Toyo 295/70/18 MT ADD honeybadger rear bumper
    Does anyone know what minimum lift I need do to fit approximately 35s and if I can keep my stock Trd pro shocks?
    I would also prefer to keep my stock 18 inch wheels
  2. Dec 26, 2015 at 8:03 PM
    I do not own a Pro, and I am not sure about fitting 35" tires on a stock "Pro" suspension. Why pay the extra$$$ for a Pro and then want to alter the suspension to fit 35''s?. Just sayin. That's why Toyota makes the SR5, which makes it somewhat cheaper to upgrade. You might be able to run with 35" already, as is.
    stsab likes this.
  3. Dec 27, 2015 at 6:03 AM
    Ubc2361
    Ubc2361 New Member
    Tony
    Los Angeles
    Tundra crewmax 5.7 4x4
    I have a sr5 crewmax 15 I can't put 35s on mine. I just bought a rough country leveling kit (2.5") n they telling me max tire size is 305 70.
    IsaiahCanada likes this.
  4. Dec 27, 2015 at 7:13 AM
    Worm
    Worm [OP] Worm187
    I might have messed up with the pro.
    Was just wondering if I could put spacers and shackles to achieve enough height to fit 35ish tires. Without changing wheels and shocks. Having trouble resisting the desire to put the biggest tire possible with my good suspension. If not I'll go with 305 70s.
  5. Dec 27, 2015 at 7:18 AM
    Bl@ckBea$t
    Bl@ckBea$t New Member
    12 Blk Dbl cab
    Dual 12x6 BaMuffler's, Rear-cat Delete, TRD Sway Bar
    You can fit 35's no problem with your trd pro shocks. You are on the right trail by adding shims (not spacers) and shackles in the back. Get in contact with David Ekstrom (<ekstrom_design@yahoo.com>) and he will give you exactly what you need.
    Basically you can achieve the lift you want (3in) with your trd pro shocks to fit those 35's. You do not have to buy new suspension.
    allstar617 and Black Wolf like this.
  6. Dec 27, 2015 at 7:21 AM
    Worm
    Worm [OP] Worm187
    Thanks so much for the info
    I was almost worried I was a dumb Tennesseean
  7. Dec 27, 2015 at 7:23 AM
    The Pro suspension is very decent. There are some Pro owners here who have upgraded their tires but I can't remember if 35"s were used. There are some things you can do to get you more clearance to lessen the amount of rubbing by using cab mount chop plates [​IMG] from Relentless Fabrication. http://www.relentlessfabrication.com/products/05-tacoma-cab-mount-chop-plate A lot of guys here including @Sean266 have also trimmed their front bumper. I think @Sean266 has pics posted on his build thread of both these options which should allow you to use 35" with no problems.
    jimbrophotodotcom and SeanO86 like this.
  8. Dec 27, 2015 at 7:27 AM
    Check out @tat2ude39 's Pro Build thread here. He has done a lot of neat stuff to his Pro.
  9. Dec 27, 2015 at 7:31 AM
    Worm
    Worm [OP] Worm187
    Thanks
    Things are looking up for my pro.
  10. Dec 27, 2015 at 7:34 AM
  11. Dec 27, 2015 at 8:29 AM
    Side note: We added a 3rd Gen TRDPro sub-forum as we seem to have a lot of Pro's on here joining...everything 3rd Gen TRDPro related has been moved to this sub-forum.
  12. Dec 28, 2015 at 3:30 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Two Coachbuilder shims on each side will give you one inch of additional lift. Then if you choose a proper offset (around 35 mm), then you should be able to fit 35s (stock wheels with 35x12.5 will give you a rubbing problem with control arms--which is really bad). The rear can be lifted up by Coachbuilder shackles. 3 inch shackles will give you slight more rake. If you don't like that, you could always go with smaller shakes (2 in).
    His stuff are legendary among various forum members for their beefiness and quality.
    15whtrd likes this.
  13. Jan 5, 2016 at 7:56 PM
    Stelly
    Stelly New Member
    2016 TRD Pro, Crew Max, Metallic Gray
    TRD Rock Warrior 17" Wheels, BFG Tires 315/70/17 KO2's, 1.25" front spacers, TRD Intake, N-Fab BAJA Pro Bumper, Hella Lights, LED fog bulbs
    OK what am I missing here. I have the Coachbuilder shims, haven't installed them yet, but they are .25"ea, 2 of them = .50", how does that raise the front 1"?
  14. Jan 5, 2016 at 8:04 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Because the shock ratio with our trucks is almost 2:1.
    BTW...for all this blah blah blah I need to lift to fit 35s. You can fit 35's on a bone stock Tundra. You don't need to lift anything.
    I'm still amazed how everyone seems to think that coilover lifts, spacer lifts, TRD Pro lifts, etc. have some magic property that change tire clearance on compression. All those lifts only change clearance at ride height. The suspension still moves up and down. First time you stuff the tire in a driveway, you are back to normal. But I digress.
  15. Jan 5, 2016 at 8:41 PM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    This ^
    Mine is not even leveled I'm still a little low in the front and I can stuff 35's with just a little trimming and removing the front plastic.
  16. Jan 6, 2016 at 4:23 AM
    Worm
    Worm [OP] Worm187
    It's looks good
    But do you rud when compressed?
  17. Jan 6, 2016 at 5:44 AM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    Only a little on the cab mount at full lock.
    dcsleeper408 likes this.
  18. Jan 6, 2016 at 6:30 AM
    ToyotaTundraMike
    2015 Tundra
    Pretty sure I have seen where guys are running 295/70/18 without problems with the TRD Pro. That's about a 34.5-34.7" tire if im not mistaken, depending who makes it. Almost 35, and close enough IMO. The ones I have seen look great, wish I would have just got a PRO myself.
    Bigbird57 and dcsleeper408 like this.
  19. Jan 10, 2016 at 12:26 AM
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    @PLC721 Mentioned it's also possible to rub the skid plate with certain setups right? I'd want to use my old 35/12.50r17s if I could and just buy some methods. I'm more than prepared to chop the cab mount and do some trimming if needed, just don't know what else I should prepare for if need be
  20. Jan 12, 2016 at 11:04 AM
    jberry813
    Lake Tahoe
    Which Methods?
  21. Jan 12, 2016 at 5:07 PM
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    If I go with 17s I'd get the standards, but after some more thinking I'll prolly buy new R/Ts for the stock 18" wheels. With that idk if I need spacers as well..
  22. Jan 12, 2016 at 5:17 PM
    Island woody
    Island woody New Member
    Scott
    2016 crew max 4x4
    Lift kit, Borla exhaust, 35 inch tires
    pro comp lift with 35 12.5 20 and still had to remove plastic front inner fender trim to not rub
  23. Jan 13, 2016 at 12:09 PM
    jberry813
    Lake Tahoe
    Might want to reconsider that decision. The 17's in a Standard have a 4.75" BS. A full inch farther out than the Standard 18's with 5.75" BS. 4.75 is too little backspacing IMO for our trucks with 35s.
    I trimmed my skid plate and did a CMC and the 35's are basically perfect. With 4.75", I'm not even confident the CMC would be enough to clear.
    dcsleeper408 and TRON[QUOTED] like this.
  24. Jan 13, 2016 at 12:58 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    I've cleared a 35x13 on a -44mm offset with the CMC and a 6" ProCrap lift.
  25. Jan 13, 2016 at 1:17 PM
    jberry813
    Lake Tahoe
    44mm offset with what width wheel?
    And that's a DB lift. Apples and oranges.
  26. Jan 13, 2016 at 5:16 PM
    Relentless
    Eric
    Yeah DB, does change shit.
    20x12 wheel
  27. Jan 14, 2016 at 6:13 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Does anyone here run a DB lift?
  28. Jan 14, 2016 at 8:00 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Will you be attempting on a stock pro suspension? If then there are a few things to take into consideration.
    Back space and offset come into play a lot when thinking about stuffing 35's in there.
    I'm 90% sure you can stuff 35's in the wells w/ the Rock warior rim setup b/c of the offset. BFG doesn't recommend 12.5 on a 8" rims. If I remember right it'd have to be 8.5/9", but there are countless folks that put 35x12.50 on rock warriors with no problems.
    I would consider aftermarket UCA(which also depends on you off set/ backspacing), Body chop mount FOR SURE, removal/cutting/moving around plastics.
    Haven't clarified yet about the front skid. As Pro skids look different than the factory skid. When I do my next service I will make sure to double check. As factory skids, people do Mod, as far as cutting or bending the "ears" to provide more clearance on lockouts.
    Also consider running CB shims+shackles if all else fails on stock pro suspension
    Question is do you plan to go wheeling? As I'm sure if you are just rolling around the city you can get away w/ 35's with slight rubbing on u turns and all that fun stuff..
    I am more worried when the suspension cycles/articulates at full compress with the 35"s under there.
    I will attempt this in the near future once I decide what rims size/offset/bs I will need to accommodate the 35"s at full compress etc..
    motod6 and TRON[QUOTED] like this.
  29. Jan 15, 2016 at 9:35 PM
    Robbeidleman
    Robbeidleman New Member
    Rob
    2016 grey tundra trd pro
    I just went ahead and decided to have suspension removed and I'm gonna have them install a 6" pro comp stage 2 lift with front coilovers
  30. Jan 16, 2016 at 4:48 AM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    :notsure:
    15whtrd likes this.
