mini projector headlight question
Discussion in '1st Gen Tundras (2000-2006)' started by rrod, Feb 1, 2024.
  1. Feb 1, 2024 at 10:19 AM
    rrod
    rrod [OP] 2005 AC Tundra SR5 4x4
    Rob
    Aluma Series, JBA UCA, Wheelers add a leaf
    I know this topic has probably been played out but I just got around to doing this mod. So for anyone watching the Youtube videos and planning on going for it. Here is somethings I ran into and either missed or did not understand. I ended up with a weird light pattern, kinda like a mountain peak / \ instead of the ___ . For dummies like me, it was the torx adjustment screw in the middle of the projector that needed to be loosened and adjusted. Hence why there is an included torx tool with your projector. It seems simple but at 8pm after work and rushing, I was clueless! Additionally, I did experience the documented issue of losing the fog lights upon projector installation. The following day I installed the relay suggested by Tyler208 on youtube and with just one relay installed, all went back to normal and operational again.
    ** Now I'm having an issue with the projector on the driver side not adjusting down, also it seems the housing clip keeps coming loose and the projector goes out of alignment as its wobbling freely! Other than that, the light output is quite impressive as others have stated. Im hoping to resolve these little issues to give this Mod a fair shot.
    I installed a $10 amber LED into the DLR slot (2005 and up lenses) and boy does that look slick with the new housings. BTW, I got them at Rockauto and went with the DEPO housing which are nice quality. Anyhoo, dont mean to belabor the topic, just want to help someone looking to do the mod.
    Weagle likes this.
  2. Feb 1, 2024 at 10:28 AM
    Did you buy the same COlight projector?
    The cutoff on each bulb is supposed to be like _____/¯¯¯¯¯¯
    So when you get them properly aligned it should look like __/¯¯¯¯¯¯/¯¯¯¯¯¯
    You should NOT need to adjust any bolts on the bulb, and I wouldn't recommend doing that. If you bought those from COlight and you think you got a defective bulb, contact them so they can replace it. I have no idea what you actually did (and if you should've done it) by tweaking on that bolt, but ... I suspect you may've just un-calibrated the bulb somehow.
  3. Feb 1, 2024 at 7:31 PM
    Likely just loosened the set screw, rotated the bulb to line up the cutoff horizontally and then tightened the set screw. I had to do that on mine as well.
  4. Feb 1, 2024 at 7:34 PM
    Really? I just spun to loosen the heatsink on mine, spun the bulb, then tightened the heat sink down again, if memory serves.
  5. Feb 1, 2024 at 7:36 PM
    Now you got me second guessing. The LED bulbs in my daughter’s projectors were a set screw for sure. I do remember the heat sinks having to unscrew to get the bulb in the housing seated and get the boot back on them. Hmmmm.
  6. Feb 1, 2024 at 7:46 PM
    Okay, not going crazy
  7. Feb 1, 2024 at 8:04 PM
    Hmmm. I don’t remember that. And I can spin the bulbs in the housing for fine tuning. Is that the screw OP is talking about though?
  8. Feb 1, 2024 at 8:06 PM
    Sounds like it. Torx in the middle of the light housing. Included tool.
    shifty`[QUOTED] likes this.
  9. Feb 2, 2024 at 4:37 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Mine seems to be designed a little different from the ones pictured earlier ITT
    it appears to me the included tool (allen) and screw on mine is to resolve the problem others experienced where the light was pointing too high, beyond the adjustment screw limit on the light assembly, which caused them to have to adjust the whole light assembly. This caused the light assembly to jut out beyond the hood at the top
    I believe it is intended to be on the bottom and by screwing it in further it points the light beam lower
    that whole wheel, for lack of a better term, will spin around so that you can have that set screw at the bottom. If I am not mistaken, the headlight assemblies are designed where the light is installed with 2 fingers or prongs equidistant at the top and 1 at the bottom.
    With the set screw at the bottom you can easily adjust the light beam lower by screwing the set screw in further
    I suspect that's why these lights disappeared, and were replaced by the next generation, so as to resolve that issue
    it has the added benefit of making the headlights easier to align. at least in my experience, it was very difficult with the light assemblies and I had to take mine off the truck to make adjustments
  10. Feb 2, 2024 at 5:44 AM
    Ah, I thought you were referring to this fastener, and I was, like, "Uh, it's probably a bad idea to mess with any of those three..."
    Weagle likes this.
  11. Feb 2, 2024 at 5:45 AM
    Weagle
    Prattville, AL
    That was someone else and his appear to be designed differently. It was confusing to me as well.
    On mine that Allen wrench does not fit that screw although I did try it after reading his post. That's when I found that set screw and realized the purpose
    I don't think it's in the instructions. Although I'd have to have a magnifying glass to read them. And they seem to be too brief to reference that screw
    hard to tell from the pic, but @KNABORES don't appear to have the set screw that is on mine to adjust the light downward.
    Also hard to tell without a pic but it didn't sound like @rrod were to lower the light beam either
    I should have a chance to try mine this weekend.
    If you were one of the ones that had to adjust your whole light assembly, it might be worth the 34 bucks to get the version like mine
  12. Feb 2, 2024 at 6:18 AM
    Weagle
    Prattville, AL
    Where did you get the amber light?
    and if you're still having a problem getting your light lower as you mentioned I believe on the passenger side, look for that set screw like mine in my earlier post with the picture
    Edit: I see now you were using the set screw to steady the light. Try to spin/adjust it where the set screw is at the bottom and then you can use it to lower the light beam
  13. Feb 22, 2024 at 3:34 PM
    rrod
    Rob
    Knabores hit the nail on the head, his picture shows the exact (torx?) screw that I needed to loosen to adjust the light angle. BTW, they have been adjusted in the horizontal orientation now and i lowered the lights via the Philip screw housing on the headlight housing. All seems good now and they are working quite well. I guess the confusion stems from the different mini-projectors out there so be aware your mileage may vary.
    heres my culprit: You can see how you can twist the projector side to side once loose to adjust the angle. I did not see this explained anywhere - hence why I wanted to make this post in case someone else ran into the issue.
  14. Feb 22, 2024 at 6:14 PM
    I shared a screenshot from the post above from the other thread on these lights where I explained using the set screw to adjust the angle of rotation. Mine did not have a screw to adjust the elevation angle however.
    Weagle likes this.
  15. Feb 23, 2024 at 5:50 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Mine had the Torx set screw. I loosened it and adjusted by looking at the bulb in the housing with the flat side sitting on my table. Was able to TLAR it close enough. My PAX side is canted maybe 1-2 degrees but not worth a disassembly.
