Miles when you pick up….
Discussion in '3rd Gen Tundras (2022+)' started by jeosbor1, Jul 8, 2022.
  1. Jul 8, 2022 at 6:08 PM
    jeosbor1
    jeosbor1 [OP] New Member
    North Carolina
    2022 Lunar Rock Limited TRD OR
    4 miles on the odometer when I picked up the truck. Dealer put gas in it prior to me picking it up.
    Interesting to hear about others.
  2. Jul 8, 2022 at 6:18 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    In today's car market you should never see more than 10 miles on the odometer when picking up a brand new vehicle. Unless.. its been on countless test rides for whatever reason Lol.
  3. Jul 8, 2022 at 6:44 PM
    mrfreeman
    mrfreeman New Member
    Kenny
    Buffalo
    2024 Tundra SR5
    Mine also had 4 miles the day it arrived, test drive made it 7.
    jeosbor1[OP] likes this.
  4. Jul 8, 2022 at 6:49 PM
    MJPlat
    MJPlat New Member
    Mine had 6
  5. Jul 8, 2022 at 6:51 PM
    CamsRetriever
    CamsRetriever New Member
    Roseville, CA
    2022 Platinum CM MGM
  6. Jul 8, 2022 at 7:18 PM
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    Ditto
  7. Jul 8, 2022 at 7:22 PM
    Supes1903
    Supes1903 New Member
    2022 Tundra Platinum
  8. Jul 8, 2022 at 7:54 PM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    2 when I arrived, 11 after my test drive and the dealers gas up…
  9. Jul 8, 2022 at 7:56 PM
    splashflash
    splashflash New Member
    Art
    Timnath, CO
    2022 SS Red SR5 Sport Premium
    I had 3 after picking it up. Apparently they had to drive it that much to "turn on" the safety features
  10. Jul 8, 2022 at 8:09 PM
    mannyg84
    mannyg84 New Member
  11. Jul 9, 2022 at 8:38 AM
    SWPDXer
    SWPDXer New Member
    2013 Tundra SR5 DC TRD
    Stock
    Same here. Picked up a Limited DC Lunar Rock TRD OR that someone had cancelled. I only waited three weeks for it. Two miles on it, they filled up with gas and cleaned. Love it. Much superior in driving experience to my 2013 DC TRD. Vancouver WA Toyota.
  12. Jul 9, 2022 at 8:55 AM
    Chapp
    Chapp New Member
    2022 Tundra TRD Off Road
    Stock....for now
    I believe I had 8 on mine, although I didn't order mine and the tank was full.
  13. Jul 9, 2022 at 9:09 AM
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    Mine had 5k. It was a dealer demo. It was on the only Tundra on the lot and available and had everything I wanted. I chose to take it instead of waiting who knows how long for a like model to arrive. And I received a full tank of gas.
  14. Jul 9, 2022 at 10:04 AM
    AustinTexas
    AustinTexas New Member
  15. Jul 9, 2022 at 10:25 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
  16. Jul 9, 2022 at 10:31 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    100% Stock
    300..back in February when there was a bit more inventory. Dealer had a 7k MA and I think that's why it hadn't sold. Took it on a test drive and we filled it up with premium, drove it home after.
  17. Jul 9, 2022 at 10:40 AM
    22PlatWCP
    Mississippi
    Hope you're not wasting your money on premium now that you're buying the gas.
  18. Jul 9, 2022 at 10:46 AM
    eddiefromcali
    Eddie
    100% Stock
    I am
  19. Jul 9, 2022 at 11:42 AM
    22PlatWCP
    Mississippi
    Why? From the owner’s manual:
    Fuel type
    Unleaded gasoline only
    Research Octane Number
    87 (Research Octane Number 91) or higher
    Fuel tank capacity (Reference)
    Standard fuel tank:
    22.5 gal. (85.0 L, 18.7 Imp.gal.) Large fuel tank:
    32.2 gal. (122.0 L, 26.8 Imp.gal.)
    philly215 likes this.
  20. Jul 9, 2022 at 11:47 AM
    FBurg22Tundra
    FBurg22Tundra New Member
    Four and a full tank
  21. Jul 9, 2022 at 11:53 AM
    eddiefromcali
    Eddie
    100% Stock
    1. Because I want to
    2. Because I have a JB4
    3. I mix E85 and 91 for an E40 blend and run the appropriate tune.
    With a forced induction 10.4:1 compression ratio, I'm confident that the higher octane helps take advantage of any timing the ecu can throw at it. Regardless if it comes from the E85 or Premium gas
  22. Jul 9, 2022 at 11:59 AM
    Roctane84
    Roctane84 Tread On Them
    Louisiana
    ‘22 TRD Pro Solar Octane (SOLD)
    3 with a full tank
  23. Jul 9, 2022 at 2:04 PM
    SupaCoopa
    SupaCoopa New Member
    2022 Tundra 4x4 Crewmax
    I feel used - Mine had like 17 miles on her.......She was worth it though - drove her 250 miles home.
  24. Jul 9, 2022 at 3:10 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    6 and a full tank.
  25. Jul 9, 2022 at 7:44 PM
    GQ104
    GQ104 New Member
    8 miles on mine- i did see them drive it back from the gas station and then washed it
  26. Jul 10, 2022 at 7:45 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    How is the JB4? Are you moving your fuel 50/50? I'm just curious cause, I may get the JB4 eventually. Can you tell a difference with it?
  27. Jul 10, 2022 at 7:51 AM
    Kur
    Kur New Member
    Mesa, AZ
    08, 5.7, Double Cab Tundra, White
    Because https://daptuning.com/faqs
    "As we have reported with every truck we have tested on, 4.6L, 4.7L, 5.7L, all run best on 91+ octane whether they are completely stock with stock tune, or tuned. These engines pull 8-12 degrees of timing due to knock retard on 87 oct, 6-10 deg on 89oct, 2-6 deg on 91oct, and 0-2deg on 93oct. That is on a completely stock truck with factory tune.
    If you care about the engine in your $35,000-$65,000 truck as you think you do, you wont run anything but premium in it weather you are tuned or not tuned.
    eddiefromcali likes this.
  28. Jul 10, 2022 at 7:55 AM
    Kur
    Kur New Member
    Mesa, AZ
    Mine only had 177,000 miles when I picked it up. It was legitimately in amazing condition. Looked brand new. I recently did my first oil change on it after driving it 5k miles on the oil that was in it when I bought it. The old oil came out only slightly darker than the new oil I was putting in. And there was an Amsoil filter in the filter housing. I also found 14 years of oil change records in the glove box when I took the truck on a test drive.
    I'm pretty confident the previous owners babied the hell out of my truck and stuck meticulously to the preventative maintenance. As long as I can manage to do half as well as they did, I'm sure I'll get another 200k or more easy.
    Retired...finally and 1lowlife like this.
  29. Jul 10, 2022 at 7:55 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Did they still charge you the dealer markup? :rofl:
  30. Jul 10, 2022 at 11:44 AM
    TWade
    TWade New Member
    Tanner
    The dealership I bought from does not markup.
    omgboost[QUOTED] and Rockgate like this.
