Miles to Empty
Discussion in 'General Tundra Discussion' started by TXMiamiFan, Dec 18, 2015.
  1. Dec 18, 2015 at 7:26 PM
    TXMiamiFan
    TXMiamiFan [OP] SSEM #3 and tractor extraordinaire
    Jose
    2016 White Crew Max TRD
    Hello. Just wondering if anyone has info on how miles to empty are calculated. When I first got the truck at the dealership it read 599 miles to empty. Second fill up said 579 and today it read 561. How could I have lost 38 miles so fast? Does the computer recalibrate after seeing you average as you use the truck?
  2. Dec 18, 2015 at 8:16 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Yes it uses your average mpg to show the miles to empty.
  3. Dec 18, 2015 at 9:50 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Your truck needs time to "learn" before it gets to be more accurate.
  4. Dec 18, 2015 at 11:12 PM
    ^^ yep.
  5. Dec 19, 2015 at 4:41 AM
    PolarbearTRD
    PolarbearTRD New Member
    Newton Nh
    2015 white crewmax TRD
    Carbon fiber wrap trim interior. Carbon fiber pillars, yitamotor 6000k led headlights. Rigid industries 50" led light bar,
    One fill up i will be at 349 then next I could be at 356 and a different number every time I fill up
  6. Dec 19, 2015 at 4:53 AM
    cfdfireman90
    cfdfireman90 New Member
    Cory
    Southern NH
    2015 Tundra Limited/TRD Double cab
    I typically show around 315 after a fill up. I usually have 6 gallons left when the low fuel light comes on.
