Miles on spark plugs
Discussion in '1st Gen Tundras (2000-2006)' started by tundrainsc, Nov 1, 2021.
  1. Nov 1, 2021 at 6:55 PM
    tundrainsc
    tundrainsc [OP] Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    My 06 4.7 has 166 k on the original plugs. It runs like new and gets 14 mpg in town. What's the most miles others have gotten on a set of original plugs. I am thinking about changing them out, but I have been waiting for signs of wear ie: low mileage or performance.
  2. Nov 1, 2021 at 6:58 PM
    Blueknights75
    Ron
    Clayton, NC
    Have you pulled one out to see how it looks?
    Cock-A-Doddle-Do and Tundra2 like this.
  3. Nov 1, 2021 at 7:20 PM
    tundrainsc
    06 Limited 4.7 2WD
    No, plan to. Have to pick up a socket appropriate to reach in the recess. Any suggestions for a reasonably priced one?
  4. Nov 1, 2021 at 7:29 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Replace them w/ OEM Denso Iridiums.
    Don't buy them off Amazon or ebay . . . there's fakes out there.
    Buy from a reputable store.
    Check your coil packs for cracks while you're in there.
    Don't use anti-seize on the plug threads.
    Torque them appropriately.
  5. Nov 1, 2021 at 10:56 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    I’m not fully sure I support the replace cracked coil packs. I’m at 285k all original coil packs and they are burnt, puffed and cracked and are still working perfect. They have been this way for 80k.
    I did have to replace the rubber components (plug boot and valve cover seal) with ones from NGK as Toyota doesn’t sell them separately.
    Darkness and HBTundra[QUOTED] like this.
  6. Nov 1, 2021 at 11:26 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    You got a link or part # for the rubber components?
  7. Nov 2, 2021 at 3:12 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Darkness and HBTundra like this.
  8. Nov 2, 2021 at 5:55 AM
    06yotamike
    06yotamike New Member
    NC
    2006 Tundra DC XSP 4x4 4.7 Bluesteel Metallic
  9. Nov 2, 2021 at 7:42 AM
    Spark plugs are a wear item. The old coppers wouldn't last more than 25k miles before they burnt down to nubs. The newer Platinum and Iridiums are much more durable. I do 100k mile changes on those types of plugs unless there's symptoms. Hate to wait for something to fail that's a wear item, but sounds like you've gotten a lot of bonus time out of those.
    Darkness likes this.
  10. Nov 2, 2021 at 9:27 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I'd really like to see some pics of these 166K plugs that are only supposed to last to 30K. Hopefully, they aren't seized in the block.
  11. Nov 2, 2021 at 9:36 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    replace the plugs. asking for trouble leaving them in there 15 years!
    Darkness and Jack McCarthy like this.
  12. Nov 2, 2021 at 9:46 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I replaced mine at just over 60K miles on my 2006 DC . . . they looked fine, but did it anyways.
    One thing I noticed was some were much tighter/looser than others.
    That being said, I'll be checking the torque on them every 2nd or 3rd oil change from now on.
  13. Nov 2, 2021 at 10:04 AM
    blrroman27
    blrroman27 New Member
    2021 Toyota Tundra SR5 Trail Edition
    n/a
    Saw this earlier on FB. Sorry had to black the name out. But this guy, has 300k on his Tundra and has never replaced his spark plugs until few days ago and check out his spark plugs.
    bmf4069 and HBTundra like this.
  14. Nov 2, 2021 at 11:54 AM
    06yotamike
    NC
    Factory plugs on an 06 (VVTI) should be iridium, so change every 100k. But i think we all still want to see them at 166k. But I bet they still look good.
  15. Nov 9, 2021 at 2:47 PM
    tundrainsc
    06 Limited 4.7 2WD
    I changed the plugs in about one hour today. Some were barely snug and others tighter. All came out smoothly and new ones went in smoothly. Torqued to 18 ft lbs. Coils looked good . No cracks. Used the plug tool 06yotamike recommended. Worked great and the price was good. Drove a few miles after the change and could not tell any difference in performance. It was running like new before and after the change. But now I am set for my lifetime as far as plugs. LInk to old and new plugs https://www.dropbox.com/t/raYpk6DShV7U0KWc
    Darkness and 06yotamike[QUOTED] like this.
  16. Nov 12, 2021 at 10:43 AM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    What is the correct part number AND gap setting for the 05-06 V8 engines.
  17. Nov 12, 2021 at 1:55 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Punk1974 likes this.
  18. Nov 12, 2021 at 5:20 PM
    tundrainsc
    06 Limited 4.7 2WD
  19. Nov 13, 2021 at 8:35 AM
    If you order today you can save $20 instantly without adding anything using the coupon CHRISFIX25 for Advance Auto
    I think I may forego the Iridiums and get whatever the latest, better tech is, Rhodium or something? Ruthenium? Hell if I remember.
    And what's the diff between the IK20TT and IK20? I forgot.
  20. Nov 13, 2021 at 9:52 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Thanks shifty. Just ordered some Densos (already have a stash of 8 on the shelf for the Tundra) for the Highlander. Got the IK20TT series ones as Denso Global's website noted them as appropriate for the vehicle (Owner's manual lists the FK20HBR8's). The CHRISFIX25 discount absolutely works!!!! I got 6 with tax for $44.
    shifty`[QUOTED] likes this.
  21. Nov 13, 2021 at 3:44 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    If you get 14 in city, in a 15 year old v8 over 150K, replace them with the same damn thing or the modern equiv. Thats brilliant, and why I drive toyotas.
  22. Nov 14, 2021 at 6:25 PM
    I had similar confusion. Manual for my '06 calls for "KS20R11" but there is no such plug. I think it's a typo in the manual, S and K reversed and the SK20 R11. I had $5 off coupon from other stuff so went ahead and stacked it with the discount just to have a spare set on-hands. I have yet to pop my plugs out and inspect since owning the truck, no reason yet. For all I know they're brand new and I may not be swapping out for another 40k+ miles.
    HBTundra likes this.
  23. Nov 26, 2021 at 6:09 AM
    tundrainsc
    06 Limited 4.7 2WD
    After replacing the plugs I went on 308 mile trip mostly at 70 mph. Topped off with 90 octane before leaving and upon return. Used 17 gallons = 18.11 mpg
    HBTundra and Chevy9124 like this.
