Mileage and repairs
Discussion in '2nd Gen Tundras (2007-2013)' started by 2015TundraCrewXP, Oct 9, 2018.
  1. Oct 9, 2018 at 8:33 AM
    2015TundraCrewXP
    2015TundraCrewXP [OP] New Member
    Charles
    SC
    2015 Black Tundra Crew Max XP
    20" blacks wheels, trd pro grille, color matched fender flares and handles, steel rear bumper, black leather, bakflip cover, spyder led headlights
    How many miles do you have on your tundra? What mandatory repairs (@ what mileage?) have you had to do?
  2. Oct 9, 2018 at 9:59 AM
    SouthWestGA
    SouthWestGA New Member
    We have a 2008 Sequoia which is similar to the Tundra drivetrain. It has 208k and has had regular fluid changes and brakes/tires. Other than that,it hasn’t needed anything major.
    teedubbya likes this.
  3. Oct 9, 2018 at 10:17 AM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    82k 2013 nothing but regular maintenance at this point
  4. Oct 9, 2018 at 10:21 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    80k 2012 nothing but maintenance and had to deal with the AIP issue. Other than that, no problems.
  5. Oct 9, 2018 at 10:37 AM
    93.3K on my 07......fluid changes only so far. Normal wear and tear. Everything still working great.
    TheBeast likes this.
  6. Oct 9, 2018 at 10:40 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    2008 4.7l. It has 138k. I’ve had the plugs changed at 120k, transmission flushed, timing belt and water pumped replaced, brakes, and aip issue under warranty. I need to change the differential fluids and transfer case but that’s it. All routine stuff.
  7. Oct 9, 2018 at 10:42 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    130k on 2007 5.7, 3rd owner. 2nd owner nor Carfax history revealed any major maintenance items. I have done fluids and front/rear brakes.
  8. Oct 9, 2018 at 10:56 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    69,000 miles. Repairs to date:
    Cam tower leak repair at 14,000 miles.
    Upper ball joints at ~30,000 miles.
    Driver's front shock needed replaced at ~ 30,000 miles.
    Serp belt tensioner replaced ~50,000 miles.
    Lower ball joints at ~68,000 miles.
  9. Oct 9, 2018 at 11:17 AM
    15whtrd
    15whtrd Mr. Blonde
    24k LOL i’ve change the oil every 5K and front and rear differentials, and transfer case fluid. I did have the clock spring grenade on me for some weird reason. Covered by warranty. Also I need to get my radio updated it keeps freezing up on me. Other than that zero issues.
  10. Oct 9, 2018 at 11:58 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    2010, 134K, and the only non-maintenance repair was a driver side front axle at about 65K...that's it.
  11. Oct 9, 2018 at 12:05 PM
    TheBeast The Beach
    cam tower leaks repaired under warranty at 58K. other than that been trouble free. Just regular maintenance. 70K now.
  12. Oct 9, 2018 at 12:16 PM
    Ericsopa
    Ericsopa Old man and the sea
    2013 CM, 96k......nothing but fluid/filter changes.
