Mild burning smell…
Discussion in '2.5 Gen Tundras (2014-2021)' started by ConcordCarlos, Jan 9, 2022.
  1. Jan 9, 2022 at 5:30 PM
    ConcordCarlos
    ConcordCarlos [OP] New Member
    Carlos
    2021 Tundra SR5
    Good Evening Tundra gang. I’ve got a 2021 SR5 with about 1800 miles, for the past month it has had a mild burning smell right after start up. I kept thinking some part/piece that gets hot had some oil on it , or some sort of coating was burning off since the truck is still fairly low mile . Could not find anything, until tonight . Right near the fuel rail(I think) , above the valve covers were a bunch of chunks of semi rigid foam….and acorn husks . Found plenty of chew marks on the foam around the engine bay . The flexible grabber tool with the light on the end allowed me to get most of it . Used compressed air to clear what I couldn’t get to. I guess the rodents have good taste in vehicles . Anyone have success with rodent spray in or around the engine bay ?
  2. Jan 9, 2022 at 5:34 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Do some research and put wire mesh in your fresh air intake openings ....and check your cabin air filter.
    ConcordCarlos[OP] likes this.
  3. Jan 9, 2022 at 5:38 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    They started chewing on mine as well awhile back. Get a spray bottle and mix up some peppermint oil and water, give a good blast to the foam and other areas under the hood, worked for me. Good luck.
  4. Jan 9, 2022 at 5:38 PM
    ConcordCarlos
    Carlos
    2021 Tundra SR5
    looked in from the engine bay, looked clean. I need to do the wire mesh mod , and go check my cabin filter right now .
  5. Jan 9, 2022 at 5:54 PM
    Check all of your wiring harnesses really good. They love that soy based wiring.
  6. Jan 9, 2022 at 5:56 PM
    ConcordCarlos
    Carlos
    2021 Tundra SR5
    @Tundra234 i checked as much as i could see. They hit a Dodge Ram at work several times. They don’t seem to care for the Fords.
  7. Jan 9, 2022 at 6:03 PM
    I know Honda makes a tape that is rodent proof that you can wrap your harnesses with. Definitely try the peppermint oil. There is a full thread with info. Let me see if I can find it.
  8. Jan 9, 2022 at 6:12 PM
  9. Jan 9, 2022 at 6:23 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Honda rodent tape, basically duct tape slathered in Tabasco sauce
