Mike Sweers Interview - He wanted a Diesel Tundra (and to keep the 5.7 as an option)
Discussion in '3rd Gen Tundras (2022+)' started by borla123, Aug 7, 2022.
  1. Aug 7, 2022 at 6:23 AM
    borla123
    borla123 [OP] The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    Sharing a news feed that came cross. I found interesting and learned some new stuff.
    Speers is not the one that killed these engine options. Diesel compliance in the US and the coming EPA legislation killed them as Toyota was intent on meeting the requirements. According to the interview he tried to keep the 5.7 but they said no.
    When I watched early videos of him praising the new engine, I thought he abandoned the 5.7 but he was merely supporting the new engine, after being told no on the Diesel and the 5.7.
    To meet standards and stay within a weight range, they had to take 400 lbs out of the old design in order to beef up the cooling for the new engine, which has smaller turbos than the competition but they run much higher boost at 20 PSI. This confirms the reason for all the piping in front, and the space needed there.
    He doesn't rule out a Plug In Tundra, but the next steps are to bring Fuel Economy higher with the V6.
    https://carbuzz.com/news/toyota-wont-rule-out-plug-in-hybrid-tundra
    Acedude, LukeS, Tundra'25 and 5 others like this.
  2. Aug 7, 2022 at 6:29 AM
    montera.built
    montera.built New Member
    Jordan
    2022 AG Toyota Tundra TRD Offroad
    Not sure about the 20psi thing. Everyone that I've talked to that's monitored boost levels with the JB4 said that they only had 6psi stock and bumped to the 11-14 range with the tune.
  3. Aug 7, 2022 at 6:46 AM
    borla123
    Ontario
    Maybe someone can confirm the actual boost number if the interviewer is wrong.
    The part I took note of is that the turbos are smaller than the competition, which would mean I would think, more boost is being used.
    Taking 400 lbs from somewhere else in the truck is a lot. All in support of the new engine.
  4. Aug 7, 2022 at 6:56 AM
    Will816
    Will816 New Member
    Will
    Idaho
    2022 Limited iForce Max TRD Off Road
    I agree here. The engine makes ballpark the same power as the Ecoboost using the same size engine so boost will be on the lower end. If it was a 2.0 liter making those numbers, sure, maybe it would take 20psi. Turbo size and boost aren't always related.
  5. Aug 7, 2022 at 7:02 AM
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    Pretty sure our trucks only make like 10PSI stock.
    At 20 I’m sure we’d be at another 100hp/140tq lol.
    =JSG= likes this.
  6. Aug 7, 2022 at 7:08 AM
    IgotSR5onit
    IgotSR5onit New Member
    Has anyone robbed people of more joy than the EPA?
  7. Aug 7, 2022 at 7:15 AM
    borla123
    Ontario
    In 1980 I was a victim of the US Pollution Control Board - whoever they were.
    I had a 1980 Camaro Z28 with a 5.7 Liter engine - just like in my Tundra.
    It made 190 hp.
    No joy.
  8. Aug 7, 2022 at 7:26 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    lol I remember those days all too well. That 305 was a weak joke.
    Every 1/2 ton Chevy I saw had that anemic 305 in it. Till about 87 when the square bodies started coming out with the throttle body full injection 350. Then the body change in 1988.
    borla123[QUOTED][OP] likes this.
  9. Aug 7, 2022 at 7:31 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    GM did the same thing in 2019 in the name of fuel economy.
  10. Aug 7, 2022 at 7:33 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My dad's 74 Firebird needed 6.6L to make that "much" power.
  11. Aug 7, 2022 at 8:03 AM
    20 PSIA is a good number. 5.3-6 PSIG is what you would read on a gauge from a stock truck at sea level.
  12. Aug 7, 2022 at 8:13 AM
    This^^^
    ColoradoTJ[QUOTED] and WBW like this.
  13. Aug 7, 2022 at 8:14 AM
    Absolute vs gauge pressure....
  14. Aug 7, 2022 at 9:03 AM
    montera.built
    Jordan
    Ahh that makes sense. I remember seeing a thread bring this up. It's been a while since I've messed with modding turbo vehicles so I'm a little rusty.
  15. Aug 7, 2022 at 9:16 AM
    I don't know a lot about turbo's but we deal with taking into account absolute pressure when calibrating pressure gauges at work.:thumbsup:
  16. Aug 7, 2022 at 9:24 AM
    xc_tc
    xc_tc New Member
    Blame VW and Chrysler for not getting any more light duty diesels in the US. It takes an insane amount of time now to homologate a light duty diesel. Seems like Mazda was trying with their 2.2L diesel and gave up after delaying their SUV many times.
    ZappBrannigan and Saltyhero13 like this.
  17. Aug 7, 2022 at 9:50 AM
    mass-hole
    mass-hole New Member
    yeah the 20 psi thing sounds like BS to me. Why would they need that much boost when its making the same torque as a 3.5 ecoboost that make it with no more than 15 psi
  18. Aug 7, 2022 at 10:03 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    It must also be remembered that more boost PSI does not necessarily equal more air volume. You can’t compare boost psi of two different turbos and engines. The only thing that can really be compared is the air volume which we don’t have the data for. For example, even just changing my exhaust out on my truck to longtube headers would cause me to lose 2 psi of boost on my gauge, but the blower doesn’t move any less air. There is just less resistance to the air flow and therefore less boost pressure buildup.
  19. Aug 7, 2022 at 10:09 AM
    mass-hole
    Boost is created by restricting flow. The turbos are feeding more air than the engine can swallow so in order to get it in it has to do so under pressure.
    Turbo size wont gave a huge effect on boost for the same power unless the turbos are so snall that they are maxed out already.
  20. Aug 7, 2022 at 10:15 AM
    And now Toyota. They are in a big class action lawsuit with their diesel’s (Hino).
    Saltyhero13 likes this.
  21. Aug 7, 2022 at 11:05 AM
    mass-hole
    Also, unless their diesel had hp/torque numbers similar or better than the 3.0 Duramax that would have been an automatic no for me.
    Towing a travel trailer into a 30 mph headwind requires a ton of HP.
  22. Aug 7, 2022 at 11:10 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    I read that too. The new Hino trucks have moved to Cummins engines now due to the emissions requirements. The EPA has ruined the diesel engine rather efficiently and effectively. They have almost completed their mission.
  23. Aug 7, 2022 at 11:20 AM
    art64
    art64 New Member
    Then that's why they stopped making those medium duty cabovers! Those have Toyota diesel engines and some were hybrid versions that the new Tundra hybrids are using in terms of design philosophy. Now, they moved to heavier duty trucks and using Cummins diesel engines. Not very powerful and torquey compared to the RAM 2500.
  24. Aug 7, 2022 at 11:34 AM
    blenton
    blenton New Member
    To boot - the EPA is basing their numbers of Nox and other emissions from a study in the 90’s that calculated them to be 300% higher than actual emissions. But no need to revise the EPA regulations with correct figures.. that would put make things easier for car manufactures and people to get diesels.
    @Silver17 is on point about boost figures and comparisons. Boost is a measure of restriction whereas Manifold Absolute Pressure (along with temperature) is a better indicator of how much air is going in to the combustion chamber.
    There were a couple of triple compound turbo setups I’ve seen - an LBZ kit was developed and built just down the road from me. They saw lots of boost pressure. A 6.4 ford with triples made something like 125psi! And only made around 1200 HP on the dyno… Sure, 1200 Ho is nothing to sneeze at, but that crazy high boost pressure shows how inefficient and inaccurate boost figures are at comparing apples to apples.
    Terndrerrr likes this.
  25. Aug 7, 2022 at 11:44 AM
    mass-hole
    Made 1200 hp at like 3000 rpm probably. So ~2200 ft-lbs. Diesels also like to run lean so a properly tuned setup might be running 18+:1 air fuel ratio so it wants to run a lot more air flow than an equally powerful gas engine.
    Its a lot easier to compare on a gas engine that has to run a narrow afr range
  26. Aug 7, 2022 at 11:49 AM
    BayRunner
    2017 Tundra Platinum
    One of the reasons why Cat pulled out of providing their diesels for stripped chassis used for Motorhomes and box trucks.
  27. Aug 7, 2022 at 11:52 AM
    sabet
    sabet New Member
    I was offered a brief insight from a toyota engineer regarding the V8.
    In his opinion, Toyota is leaving the door open to bring back the V8 with the New Tundra.
    His reasoning, is in the design of the new tundra.
    Why would Toyota design the front to be longer, wider, and bigger only to fit a smaller V6 engine? First thing he noticed when opened the hood was how much extra space could be taken out from engine bay to reduce the length from the front of the truck. This made no sense to him since a longer front will cause a worse turning radius…..unless toyota is leaving the additional space to accommodate the V8 again?
    prevent, AggiePhil and Saltyhero13 like this.
  28. Aug 7, 2022 at 12:02 PM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    They made the 3rd gen Tacoma the same way. Tons of space left up front. However, that was apparently due to pedestrian safety. Crumple zone for them. I would assume the same for the Tundra, but we can dream.
    Saltyhero13 and Cpl_Punishment like this.
  29. Aug 7, 2022 at 12:03 PM
    BayRunner
    I was under the impression that they made it longer to accommodate all the new cooling features and grilles.
    montera.built and Cpl_Punishment like this.
  30. Aug 7, 2022 at 12:04 PM
    mass-hole
    The V6 is wider with the turbos and probably longer once you include all the crap needed for intercooling.
    A v8 shouldn’t have an issue fitting anywhere a TTV6 does.
