Might have to move up to older Duramax. Advice?
Discussion in 'Towing & Hauling' started by Northwoods22, Feb 3, 2024.
  1. Feb 3, 2024 at 2:25 PM
    Northwoods22
    Northwoods22 [OP] New Member
    MN
    2013 tundra grade
    Well, absolutely kills me to say it but I may have to part ways with my 2013 DC. Truck has been absolutely solid and never ever let me down, let alone had one problem ever. I wanted to keep it forever But I’m trying to start a new business this spring ( and I would like a true 4 door for the fam) and there’s no way around it- I need a bigger truck.And i don’t really want a loan.
    I’ve been looking at 3/4 ton diesels.( or 1 ton) I would like at least a 2011. Don’t think a gasser is gonna cut it for what I need. Wanting to spend 20k or so. Anyone have any experience with these years or advice in general about Duramaxes? What about High mileage ones? I know they can run a long time but still feels wrong. What to look for? What to expect reliability wise? I would have a mechanic go through any truck prior to purchase but. I see lots of HD gassers for sale but not many diesels in those years.
    I’ll add mostly for towing dump trailer and equipment bumper pull.
    Thanks for any advice.
  2. Feb 3, 2024 at 2:31 PM
    PermaFrostTRD
    Northern NY
    Are you towing daily 50+ miles each way?
    That’s the absolute only way I’d consider a diesel.
    Metro14536 likes this.
  3. Feb 3, 2024 at 2:34 PM
    Northwoods22
    MN
    2013 tundra grade
    I mean Pretty much. Concrete work. Heavy dump trailers and equipment. Bumper pull too
  4. Feb 3, 2024 at 2:36 PM
    PermaFrostTRD
    Northern NY
    That counts.
    I’d look pre-DEF years obviously. Classic duromax- Allison combos are pretty solid. 2004-10 is really all I used to know about.
    Mattedfred and Northwoods22[OP] like this.
  5. Feb 3, 2024 at 2:53 PM
    Northwoods22
    MN
    2013 tundra grade
    Right on. I kind of figured lots would be deleted already around 2011 but who knows. I say that year because it looks like capabilities jumped up a lot around that year? At least on paper.
    I would definitely be open to those years though
    PermaFrostTRD likes this.
  6. Feb 3, 2024 at 2:54 PM
    blenton
    blenton New Member
    If memory serves, 02-04 had injector issues but were solid - if relatively underpowered by todays standards. 05-07 had overheating issues, but I think 07-10 were GTG and had the 6 speed allison instead of 5 speed (literally same transmission with different valve body). 11-16 LMM is supposed to be the sweet spot for power, reliability, and cost. However, my buddy just got is '11 back from the shop with blown head gaskets at less than 100k.
    If payload is the issue, a gas motor dually is the ticket even though a diesel will pull it way better. I think the reason you don't see many used diesels for sale is because new diesel trucks are insanely expensive, include a crazy amount of treatments (DEF fluid, DPF, regeneration, etc) which adds to complexity and cost - especially if there's an issue, and they aren't as proven. The new duramax allison isn't built by allison anymore - just approved - for example.
    However, you can get in to a work truck package 2500 duramax for less than a new limited tundra.
  7. Feb 3, 2024 at 2:56 PM
  8. Feb 3, 2024 at 3:28 PM
    You probably will not get into a good diesel at 20k. Now if you have 20k plus what you sell the tundra for, now you are in a ballpark of something to work with.
    https://www.cars.com/vehicledetail/fd1b0eac-5327-4572-bdc7-8afdd85d8e75?aff=share_other
    https://www.cars.com/vehicledetail/fe7c4aa7-64a8-428b-ab7f-28d528362ccf?aff=share_other
  9. Feb 3, 2024 at 4:16 PM
    Northwoods22
    MN
    2013 tundra grade
  10. Feb 3, 2024 at 5:55 PM
    It is actually a way better deal going new...or a couple years old.
    Prices are coming down though. Last year I could have still sold my truck for what I paid for it in 2016.
    GODZILLA likes this.
  11. Feb 3, 2024 at 7:56 PM
    So I have a little more time to focus on your questions and concerns. The snow plowing kicked my ass today.
    Like stated up above the LB7 (2001-04) was a good motor, but the injectors are a PITA to change and can be problematic at times. At the current age of these trucks, I would look for a 8.1L Vortec with the Allison. My brother has two of them and when properly tuned...they will keep up with my DMax on the flats. The large passes not so much, but that is to be expected. These are not variable vain turbos, so you only have grade braking from the Allison and you can add an aftermarket exhaust brake. This is another reason I recommend the 8.1L in these generations.
    The LLY was mid year 2004-05.5 and they ran good, but had some cooling issues in hot weather at max capacity. There was a class action lawsuit and you can look up "cool my duramax" and read all about it. These were the first years of VVT.
    The LBZ was technically only one year 2006.5-2007.5. I know, there is a little gap in the years. Early 2006 trucks were not LBZ motors and you could tell with the 8th number in the VIN. A "2" was LLY and a "D" was the LBZ. This is also the first year of the 6 speed Allison 1000.
    LMM was 2007.5-2010. First intro to having a DPF filters, EGR's, closed crankcase ventilation.. and tuning. These trucks if you go into an exhaust regeneration...drive until you are complete. You will thank me later.
    LML 2011-2016. First year of the CP4. I did a conversion on my 2016 Dmax to the CP3. You can read all about it in one of my threads. Some people go 200K miles without an issue, others notsomuch and 10-13K is removed from your wallet. So far, in over 100K miles I have not had many issues. Would I buy another? Absolutely. You can read all about the changes to the LML. The first two years (11-12) could be problematic. Allison lowered the line pressure in these trucks to get better fuel economy, which isn't great for clutches. I chose to do a transmission tune to raise the line pressure. This does raise temps a bit and a loss of .5 mpg. All good...I didn't buy a 1 ton for fuel economy.
    L5P 2017 to current...with some different transmission options starting in 2020. These trucks are beasts and you should read up on them after what I post next.
    Here is a link, not sure why I typed all that shit out.
    https://www.motortrend.com/features/1703-the-general-motors-duramax-engine-through-history/
    I would bite the bullet and go this route. Slightly used 1 ton, no 5th wheel hitch so you would have to add one if needed (easy as pie if you can run a tape measure).
    https://www.autotrader.com/cars-for...mCode=CHEVC25|LTZ&zip=80908&clickType=listing
    Another good buy, this one has the factory puck system for 5th wheel/GN.
    If it was my money, one of the two trucks above would be looked at very closely. The power is phenomenal and so are all the features.
    One last thing. Don't sleep on the gas motor trucks. We have a couple members with the 7.3L/10spd Fords and new this year is the 6.6L gas/10 speed Allison in the GM.
  12. Feb 4, 2024 at 11:01 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    A buddy of mine has an 09 GMC LMM Duramax he bought new. He says you’ll have to pry it out of his cold, dead hands. He’s at 190k miles now. It’s his daily driver and jack-of-all-trades truck. He hasn’t had any real issues except the good ol’ GM interior and its incessant rattling. The original brakes lasted 160k miles (he only drives in T/H mode). If I remember correctly, his truck is fully deleted with a mild towing tune.
    The downside is, it’s a 2500, and the door jamb payload number is 18xx lbs (I don’t remember exactly). The thing is a tank, though, and apparently underrated (sound familiar?).
    The real bummer for me going the route my buddy went with a pre-CP4 truck is that there are no crew cab regular bed 3500s before. The crew cabs are all long beds. So I’d be stuck with a 2500 with sub-2k payload unless I wanted to drive one with an 8-ft bed.
  13. Feb 4, 2024 at 12:25 PM
    Northwoods22
    MN
    2013 tundra grade
    You guys are awesome. Appreciate all the info. It’s intimidating stuff. Whole different beast. Just trying to get my foot in the door here and have a truck that’s capable and get me started with out taking on a bunch of debt right away.
    ColoradoTJ likes this.
  14. Feb 4, 2024 at 1:10 PM
    Northwoods22
    MN
    2013 tundra grade
    Those new gassers are out of my budget. But I have been seeing some 2015-16 2500’s gassers that have about same miles as my tundra does now, few years newer, for a reasonable price. Bumper pull around 13k. That would definately help me. I could be way off but I think that’s what the older deisels were rated for anyways on pulling conventionaly. Duramax would do it better no doubt. But most of my Heavy loads would be generally short ( like to the pit and back) most of my fairly long rides would be with an empty trailer or small skid loaders.
  15. Feb 4, 2024 at 1:18 PM
    I can respect that. I had to save for almost two years for my Dmax. I also sold my Tundra for a good price (paid off).
  16. Feb 4, 2024 at 1:31 PM
    @Lake.Life24 has a 6.6L gas 1 ton that works it pretty hard. I'll let him chime in.
    I have been on both sides of your dilemma...used vs new(er) and cost. I can speak from experience my 2002 HO Dodge 2500 cost me on average 619.00 per month over the 42 months of ownership. I paid 12500.00 cash for it, so that was just under 300.00 per month cost. Well where did the other 319.00 come from? Repairs. Even though I paid cash for the truck, it cost me more monthly than a more reliable newer model. Not to mention it also ruined several vacations and almost put myself and a baby on the side of the road in freezing weather in Montana.
    This thread might help you make some decisions and cost. Keep in mind my biggest costs are tires. Most everything else was a want besides the charge pipes. The hot side was going to fail and put my ass on the side of the road.
    https://www.tundras.com/threads/7-years-of-hd-gm-diesel-ownership-cost.100998/
  17. Feb 4, 2024 at 5:09 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I was in your shoes and it sucks because the tundras are awesome. But I’ve had a pretty solid experience with my 6.6l gasser. I have not been the easiest on it. Towing things I probably shouldn’t :rofl:
    for a while every weekend I helped a buddy with his tree work and I hauled stumps and logs for about 20k of the 76k I have on the truck. I have probably max towed with it for 45% of its life. Truck is solid. It’s a GMC 2021 1 ton. I did have a few items that needed fixing but nothing really mechanical. Just annoying rattles. And wouldn’t look at 3/4 just jump right to 1 ton. Payload will thank you later.
    The price is daunting, but if you own a business the tax advantages might offset the higher costs. I wouldn’t shy away from gassers today. Unless you are hooked up with a heavy trailer everyday the payback period on a diesel is hard to justify.
  18. Feb 4, 2024 at 6:41 PM
    Northwoods22
    MN
    2013 tundra grade
    I appreciate the advice. Gives me more to think about. Ya know things would be much simpler if tundras could just tow more. Ha!
    Mattedfred and ColoradoTJ like this.
  19. Feb 5, 2024 at 4:59 AM
    Lake.Life24
    Shawn
    Upstate, NY
    If Toyota made a HD I would trade in tomorrow. No question wouldnt even consult with the wife lol. A lot of us went through and understand your struggle. I talked to 2 tundra members for about 2-3 weeks to figure out what was best.
    And I am partial to GM but if you got he gas route the Ford 7.3 Godzilla with 4.30 axles is an absolute monster towing.
  20. Feb 5, 2024 at 4:30 PM
    Northwoods22
    MN
    2013 tundra grade
    I have heard from multiple people that they are awesome. Can’t believe I’m saying this but I test drove a 2014 ram 2500 with the 6.4 Hemi on accident today because of an over excited young salesman. I gotta say that truck was actually pretty sweet, it had lots of pep. And with the right gear ratio can tow a lot. Have I lost my damn mind?
  21. Feb 5, 2024 at 4:50 PM
    blenton
    blenton New Member
    Yes. But that’s because of my pre-existing biases against dodge trucks :anonymous:
  22. Feb 5, 2024 at 5:09 PM
    Lake.Life24
    Shawn
    Upstate, NY
    Hemi is almost bullet proof, its all of the other things that go wrong. Check out DirtyMonkey on Youtube. He had a Ram 2500 gasser that he beat the heck out of it. Engine and Transmission held up fine....it was all the electrical and sensor issues. But, you will find issues with all the Big 3. That is why Toyota needs to build a HD truck
  23. Feb 5, 2024 at 5:23 PM
    Northwoods22
    MN
    2013 tundra grade
    I hear ya. I’m terrified to do it, but sometimes things need to be done.
    I’ll check out that video, I wasn’t even remotely considering a ram before. Thing felt heavy duty and had lots of go. It felt way more badass to me than any gasser gm 2500 I’ve driven around the same year.
    I don’t even recognise myself in the mirror anymore!
    Lake.Life24[QUOTED] likes this.
  24. Feb 5, 2024 at 5:27 PM
    Lake.Life24
    Shawn
    Upstate, NY
    The 6.0 GM gassers suck....I would buy anything other than that engine. Ram makes a solid truck. Brand loyalty should be thrown out the window when you are talking $30K+ investment. If you like the truck that is all that matters. And when you buy a HD truck we will throw you into our group chat with the other HD owners.
  25. Feb 5, 2024 at 5:36 PM
    Terndrerrr
    Music City
    6UR-FE
    Go spend some time on the Ram trucks forum to confirm that yes indeed, you have lost your mind.
  26. Feb 6, 2024 at 5:46 AM
    Northwoods22
    MN
    2013 tundra grade
    Trust me I know, but what’s a guy to do? Tundra is not gonna cut it for me anymore. No other option but big three.
    Terndrerrr[QUOTED] likes this.
  27. Feb 6, 2024 at 5:52 AM
    PermaFrostTRD
    Northern NY
    Is a new/newer Big3 HD out of the question?
    GM 6.6 gasser 2500/3500 is a great truck and absolutely what I would purchase if I needed more than 1600lb payload / towing more than 10k even a couple of times a week. There's no such thing as an HD Tundra obviously, but from my research and anecdotally having some friends that own these, it's the next best thing.
    ColoradoTJ and Cpl_Punishment like this.
  28. Feb 6, 2024 at 6:02 AM
    Hemis suffer from lifter failure too, much like the GM gassers.
  29. Feb 6, 2024 at 6:05 AM
    Northwoods22
    MN
    2013 tundra grade
    Yeah, newer one is out of the question right now. I understand all the benefits and a used older one will end up costing you more and all that but I’m in a real world scenario here. I have a young family, I’m trying to start my own construction business, I have other equipment I need to invest in, other things that need to be paid. I’m trying to get my foot in the door here and get something rolling.. if I’m making money and if it seems smart I would totally go for a newer one in a year or two. Would I love to scrape by with my tundra? Hell yes. But tundra cannot do what I need it to do. It would be unsafe and not enjoyable for me at all.
  30. Feb 6, 2024 at 6:05 AM
    PermaFrostTRD
    Northern NY
    Wasn't that a 6.0 problem that was resolved with the 6.6?
