Mig welders, suggestions..?
Discussion in 'Recovery & Gear' started by chugs, Apr 9, 2018.
  1. Apr 9, 2018 at 8:03 PM
    chugs
    chugs [OP] New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Planning to buy a mig welder for diy projects. Been looking at the hobart 140, 190, and 210 from northerntool.com. Any feedback on hobart or similar products is appreciated.
    rons23 likes this.
  2. Apr 9, 2018 at 8:05 PM
  3. Apr 10, 2018 at 12:59 AM
    Depending on what your “DIY” projects, would depend on what size machine to buy.
    My brother is a welder, and he has a Hobart 140 for the little stuff at home that can be done with a 110V welder. All other stuff over that, he just goes into work.
    T-Rex266 likes this.
  4. Apr 10, 2018 at 1:46 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I bought the Hobart 210 a few weeks ago to learn myself, too. I like that it can run on normal household outlets -- mainly so I can practice -- but is readily capable to run off a proper outlet. So far I'm happy with it. I've only gotten a little practice with FC but am going to get a bottle of gas soon.
    ColoradoTJ likes this.
  5. Apr 10, 2018 at 2:03 AM
    I’m sure you changed the polarity for FC wire right?
  6. Apr 10, 2018 at 2:24 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've had a 140 for about 10 years, if all you're looking for is normal household type repairs it's a great machine. I figure anything structural is better left to a pro but I can at least tack it in place.
  7. Apr 10, 2018 at 2:33 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Hobart will do the job. When it comes to the Mig process, Lincoln gets my vote. Make sure your running 220 and depending on your thickness range you want a decent duty cycle. Between 40 -60. Post some pics of your welder and work. :thumbsup:
  8. Apr 10, 2018 at 2:42 AM
    rons23
    Ron
    Kill Devil Hills
    Kris you will want to run off 220 vs 110 . There are a few ways you can go about your process here. 1- You can weld with a fluxed cored wire minus gas. You can run bare wire with a 75/25 Argon/ Carbon Dioxide. The best coverage and cleaner weld is going duel shield, which is using both. A flux cored wire and gas. You will be good on 110 household for just practicing, but would jump to a 220 for your projects. Good luck . :thumbsup:
  9. Apr 10, 2018 at 2:45 AM
    rons23
    Ron
    Kill Devil Hills
    Negative TJ, wire has nothing to do with the polarity. You would change polarity to A/C for aluminum welding or when you use the Tig process. Flux Cored wire allows you to weld with no gas. :D
    mdavis and ColoradoTJ[QUOTED] like this.
  10. Apr 10, 2018 at 2:47 AM
    Spvrtan
    Kris
    San Diego, CA
    It comes already pre-wired for FC.
  11. Apr 10, 2018 at 2:50 AM
    Spvrtan
    Kris
    San Diego, CA
    I don't have a 220 outlet near the garage. The laundry room doesn't have one either. I'm sure there's one behind the oven but I'm not about to run a long extension cord from there to the garage. When I move to a new place, one of my requirements is making sure it has a proper outlet.
    I do plan on going to gas eventually but I just wanted to practice my technique with my hands. For my current projects that need to go on the truck, such as my rear bumper, I'm just taking things in place with FC but then having a friend do the final welds.
    rons23[QUOTED] likes this.
  12. Apr 10, 2018 at 2:54 AM
    Beer bet?
  13. Apr 10, 2018 at 2:55 AM
    That is off the welder in my garage. I thought the same thing, and would get a bunch of splatter, until someone was nice enough to point this out.
  14. Apr 10, 2018 at 2:56 AM
    rons23
    Ron
    Kill Devil Hills
    Why not? Whatcha got pertaining to your wire selection. I'm more on the Tig side, so I could be wrong:cool:
  15. Apr 10, 2018 at 2:58 AM
    rons23
    Ron
    Kill Devil Hills
    Well there ya go. I always ran duel shield. Interesting
  16. Apr 10, 2018 at 3:02 AM
    Solid core .035 set on Electrode Positive and when using FC .035 I swap to electrode negative. It works wonders.
    I like microbrews...:D
    My brother didn't know that either, and he is a career welder like you..he just doesn't play with little girly machines as he would say.
    rons23, TheBeast and dcsleeper408 like this.
  17. Apr 10, 2018 at 3:04 AM
    I just learned something. So if I use FC and gas, even better huh? Winning!!!!
  18. Apr 10, 2018 at 3:05 AM
    rons23
    Ron
    Kill Devil Hills
    Hahaha, your right. Learn something new everyday:thumbsup:
  19. Apr 10, 2018 at 3:07 AM
    Cool man, thought I would ask.
  20. Apr 10, 2018 at 3:14 AM
    rons23
    Ron
    Kill Devil Hills
    Yes that's called duel shield what is used at most of your shipyards
  21. Apr 10, 2018 at 3:17 AM
    Well hells bells Ron. I’m going to give that a college try!!
    Thanks man!
  22. Apr 10, 2018 at 3:18 AM
    rons23
    Ron
    Kill Devil Hills
    If you want an even cleaner weld , use helium, expensive though:eek:
  23. Apr 10, 2018 at 3:21 AM
    Oh, we use He at work. That might be out of my shade tree mechanic budget.
  24. Apr 10, 2018 at 3:35 AM
    Spvrtan
    Kris
    San Diego, CA
    Wait.. that's a real thing? I know FC can get hotter and/or better penetration but is just messy so.. do people really use FC with gas?
    dcsleeper408 likes this.
  25. Apr 10, 2018 at 3:52 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I had the Hobart 190... I cheaped out at first and bought a no name mig off Craigslist.
    Night and day between the two, if I ever need a mig again the it's either another one of those or a Miller equivalent
    Sadly I sold mine to get into tig... Which while I love it, isn't anywhere near as convenient .
    I'd also use gas out of the gate rather than FC, saves you getting annoying cleaning shit off. I'd also invest in a decent helmet. I wish I'd had my current helmet when I was doing lots of mig work, it's amazing what a difference it makes.
    dcsleeper408 and NewRider like this.
  26. Apr 10, 2018 at 4:09 AM
    rons23
    Ron
    Kill Devil Hills
    Yes. I will say this Kris, and to all if the DIY'S. If your gonna get serious and a lot of your welding is gonna be on your vehicle, I would suggest investing in a GTAW (Tig) process. It's way cleaner and your welds will be a lot cleaner, cosmetically look a lot better. It's more expensive set-up , but worth the investment.
  27. Apr 10, 2018 at 4:15 AM
    tomsinamerica
    Tom
    Wilmington, NC
    I agree 100%... You just need to budget for extra tools as tig is brutal in terms of fit up tolerances....
    Mig feels like the glue gun equivalent of welding in comparison...
    the_midwesterner and ColoradoTJ like this.
  28. Apr 10, 2018 at 4:29 AM
    rons23
    Ron
    Kill Devil Hills
    Well you always want a good fit up. A foot pedal to start with, then once you get the hang of it, you can move to other options. Slider, push button, etc. When you factor in your wire and tungsten and gas, it becomes pricey, but well worth it. You can find deals on all that just doing some research.
  29. Apr 10, 2018 at 5:03 AM
  30. Apr 10, 2018 at 6:03 AM
    rons23
    Ron
    Kill Devil Hills
    TJ, that's a nice little set-up. Definitely want to run on 220. Me personally I want the Dynasty Tig Runner, which last time I looked it was around 8k :eek:. A very solid machine that will cover all of your welding needs. For the shop the Miller Synchrowave 250/350 is a solid choice.:thumbsup:
