Michelin LTX moving on wheels
Discussion in 'Wheels & Tires' started by GNX6, Mar 19, 2018.
  1. Mar 19, 2018 at 8:36 PM
    GNX6
    GNX6 [OP] New Member
    2014 Crewmax
    TRD rear sway bar TRD oil cap (adds 25 HP, It said so online)
    I bought some Michelin LTX tires and seem to be having a problem, the wheels keep moving inside the tire. I had to match mount one tire due to high road force and when I checked the pressure sunday I noticed the Mark was a 3/4 turn out. I broke down both rear tires, wiped any remaining lube from the tires and wheels with Alcohol. Re-balanced the tires and marked them. When I got home they had moved a little bit again. Anyone else seen this?
  2. Mar 19, 2018 at 8:53 PM
    Try some bead sealer.
    boostedtrdpro likes this.
  3. Mar 19, 2018 at 9:19 PM
    GNX6
    2014 Crewmax
    Thought of that, just didn't want to goop them up. I will give it a few days to see if they move again. I have a sharp turn which is an uphill which unloads the RR and I think that is what did it before the tires were seated in fully (stuck). I will give it a few days before I rebalance again.
