Michelin Defender LTX M/S2
Discussion in 'Wheels & Tires' started by PhilSR5, Nov 17, 2023.
  1. Nov 17, 2023 at 9:49 AM
    PhilSR5
    PhilSR5 [OP] New Member
    Phil
    Alabama
    2018 Grey Tundra SR5 TRD
    Hello all
    I need to replace the four 275/65R18 Kenda tires on my 2018 SR5 TRD double cab .
    I do tow a lot mainly on pavement at all seasons.
    I'm looking at the Michelin Defender LTX M/S2 and they come with different specifications such as:
    • Load range E or XL
    • Tread Depth 14/32 or 12.5/32
    • Load index 120-123S or 116T
    • Pricing $303 vs. $285
    I would appreciate all advices, any comment or recommendations?
  2. Nov 17, 2023 at 10:49 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Your original tires were 114T.
    Either of the Michelins you show are above this. So I think you'll be fine with either one.
    That said, the Load Range E tire will probably be LT and the XL tire will be P. The XL tire will likely ride better.
    How heavy are your towing loads?
  3. Nov 17, 2023 at 11:33 AM
    PhilSR5
    Phil
    Alabama
    I'm towing a 4200dry/6000lbs max
  4. Nov 17, 2023 at 11:59 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I would probably choose the P/XL. Save a little coin and ride should be better. Either should be good though.
    ejes, ColoradoTJ and PhilSR5[OP] like this.
  5. Nov 17, 2023 at 1:00 PM
    PhilSR5
    Phil
    Alabama
    Thanks a lot for your advice :thumbsup:
    ColoradoTJ likes this.
  6. Nov 17, 2023 at 4:24 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Agreed on the XL. They will be significantly lighter as well, which will help with about everything (ride, braking, acceleration, fuel mileage, etc).
    ejes likes this.
  7. Nov 17, 2023 at 7:52 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I went from LT BFGs to stock P rated. Zero change in mpg.
    I wouldnt get P rated again
    Melikeymy beer likes this.
  8. Nov 17, 2023 at 8:22 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Any significant ride difference or degrade with the Ps when towing?
  9. Nov 18, 2023 at 5:52 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    the rated capacity of the truck is using p rated tires.
  10. Nov 19, 2023 at 10:54 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    at 50psi they feel fine with my 4300lb trailer.
    i like how the e rated drive better though. Definitely corners better and no tire sway
  11. Nov 19, 2023 at 11:16 AM
    Retired...finally
    Your trailer is almost the exact same weight as mine. When I decided to replace it will be the same Michelins that came with the truck. I run 40/43 psi all the time and they are wearing well.
  12. Nov 19, 2023 at 12:28 PM
    Melikeymy beer
    Muscogee Nation
    I didn't word my question right. I was trying to get a sense of the road manners of the LTs (compared to the Ps) when not towing.
  13. Nov 19, 2023 at 8:05 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The p rides SLIGHTY better. Not enough to justify it. I really like the cornering of the LT better
  14. Nov 20, 2023 at 7:05 AM
    Melikeymy beer
    Muscogee Nation
    I have read LTs wear quicker than the Ps. Was that your experience?
  15. Nov 20, 2023 at 3:51 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    that i cannot say. My LT were bfg at so they were bad far before the tread was gone. My p rated are OEM michelins.
  16. Nov 20, 2023 at 5:20 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    Unless 50% or more of the time you tow / haul heavy or your driving is low maintenace / off-road type situations, the LT doesn't really offer much benefit to you. That extra 10 lbs of weight per tire is just unsprung mass you don't need to deal with unless you really have a need to.
    The LT's might appear to last as long or longer because you have an extra 1.5/32nds of tread depth. Also, I'm not sure about Michelin or this tire, but often times the LT rated tires do not have the same warranty (sometimes not any) on treadlife, etc. Sometimes it is also tire load and speed rating specfic, etc. That might be something you should inquire about and read the fine print if that is something that really matters to you.
  17. Nov 20, 2023 at 5:43 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I have run these on my 2015. 116T load range. I tow a 27' travel trailer at ~ 7,000 pounds.
    Best tires I have ever owned short of looks.
    You will not regret your decision.
  18. Nov 20, 2023 at 6:03 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    I had LTX MS/2 in the factory P255/70R-18 size and without much loading or towing they were down to wear bars at 25k, for whatever that's worth. Maybe their skinniness contributed to accelerated wear, who knows. They were an improvement over the factory bridgestones but still not as good as I'd hoped.
    Now I have LT275/65R-18 Defender LTX in E-load rating and they're better in almost every way. Only when the road gets exceptionally three dimensional do they have a noticeably rougher ride. I keep them between 42-46 psi. That's one potential downside, LT tires need a higher pressure to hold load and keep temps down for some reason.
    Mileage is the same. The Defenders have gotten me just over 20 mpg a few times on long trips.
    They do throw rocks like mad thanks to the wide grooves. Watch out when the speedo gets up to about 50 after going over gravel cuz if you have a tailgater, RIP
  19. Nov 29, 2023 at 11:41 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    So i got new tires today. Went back to LT. Coopers 275/70.
    they ride amazing. Definitely MUCH better driving experience than p rated. The over flexing of the p sidewalls ruins ride quality imo
  20. Nov 30, 2023 at 5:25 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    This is good feedback. Can you try to quantify what you mean when you say "ruins"?
    What about the ride of the LT tires is better?
    What pressure were you running on the P tires?
    What pressure are you running on the LT tires?
  21. Nov 30, 2023 at 6:50 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    40psi for my LT. 35psi in the P.
    In off camber bumps, like leaving/entering parking lots at an angle, hitting speed bumps/gutters at angles yesterday that I drive past every workday. There is less side/side rocking of the truck.
    in turns, much less body roll.
    driving straight line, I do feel the smaller bumps just a little more though. Not uncomfortable imo, like the tires are reading braille.
