Mice vs Engine Air Filter
Discussion in '3rd Gen Tundras (2022+)' started by PasqueFlower, Apr 18, 2023.
  1. Apr 18, 2023 at 6:55 PM
    PasqueFlower
    PasqueFlower [OP] New Member
    2022 Tundra SR5 double cab 6.5ft bed, tow package, rear air suspension
    I want to place a screen downstream from the engine air filters to block the little bastards that are trying to set up shop… where are the intakes? Also appear there is a drain in the bottom of each air filter box. Wondering if they are getting through there too.
  2. Apr 19, 2023 at 4:40 PM
    DavidTundraOR22
    DavidTundraOR22 New Member
    Québec, Canada
    Limited Off Road
    I think they take the air near the headligth.
    And I dont know what is the foam under the filter in the air box , you think its a drain for the water ?
    PasqueFlower[OP] likes this.
  3. Apr 19, 2023 at 8:34 PM
    PasqueFlower
    So glad you noticed the white foam too. Yes I think it’s a drain. There was a bit of the white stuff sucked into the airfilter so I wondered if they chewed through the black piece to get to the white foam, or if the hole came that way from the factory. I friend who is a Toyota tech is coming over a couple weeks and I’ll have him look at it. I agree the intakes must be near the headlamps but there is an awful lot of stuff that neighborhood and I was too lazy to poke around much.
  4. May 2, 2023 at 5:03 PM
    PasqueFlower
    Nice one. Will try it.
    Mattedfred likes this.
  5. May 3, 2023 at 5:03 AM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Good read/thread on the same topic
