Method NV’s w/ spacers
Discussion in 'Wheels & Tires' started by yoneytan, Aug 15, 2018.
  1. Aug 15, 2018 at 11:40 AM
    yoneytan
    yoneytan [OP] New Member
    Asi
    14 CM
    I’m running 295/70/18 on Method NV’s and wanting to put spacers. Any recommendations? I’m seeing SpiderTrax as the preferred brand but looks like the minimum would be 1.25”. Is that too much for my setup? I’m on 3/1 ProComp lift. Thanks in advance.
  2. Aug 15, 2018 at 12:03 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Spidertrax are great but since the NV's aren't hub centric, you might need custom spacers. You'll be pushing your wheels out a lot and might incur rubbing issues. The OEM stud length requires roughly 1.25" spacer to prevent the studs from hitting the inside of the wheel.
