Method Grid owners...another steering shake story...
Discussion in 'Wheels & Tires' started by Cement.pro, Jul 19, 2019.
  1. Jul 19, 2019 at 10:52 AM
    Cement.pro
    Cement.pro [OP] New Member
    Hey guys,
    Recently purchased a brand new set of Method Grid in 18x9+18 wrapped in brand new BFG K02s 34x12.5x18.
    Long story short, the tires have been road force balanced 3 times by 2 different shops. Alignment also done. I have taken the wheels on and off myself many times trying my best to center the wheels on the hub, torqued to spec. Steering still shakes starting around 50-55mph. It happens on and off and seems to switch from the steering wheel shaking to the back seat shaking. Needless to say, im at my wits end on this, and starting to chalk this up as a hub centric issue. Tire shop confirmed tires are not out of round, and wheels are straight. Not sure what to do from this point - aside from buying new wheels that ARE hub centric, or buying new tires to try.
    Question is this - those running these wheels, are you having the same issues with steering shake?
  2. Jul 19, 2019 at 11:30 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    No issues with mine, but I'm running Nitto Ridge Grappler tires (35x12.5x18). Might be the BFG's. I hear they're tough to balance.
    TheBeast likes this.
  3. Jul 19, 2019 at 11:50 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Buddy has a first gen. and this just started after BFG install too (stock wheels)...
  4. Jul 19, 2019 at 11:56 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I have hub centric Method Con 6 wheels and BFG tires. I had the shake at the exact same speeds. Balanced them 3 times before it was fixed. Ended up having to use the "hammer on" style weights on the inside lip in addition to the stick ons. I know my set up is different, but it cant hurt to let your tire shop try.
  5. Jul 19, 2019 at 12:02 PM
    TXTundra2722
    2015 Black Tundra
    What is your lift? I thought we've also read on here an issue with certain lifts and driveline angles causing a shake. Raptors come stock with K02s so that can't be that big of an issue with balancing
  6. Jul 19, 2019 at 12:06 PM
    Cement.pro
    No lift, stock everything (TRD Pro). Tires have already been road force balanced 3 times. Tire shop said they are as best as he can do, and he put the better ones in the front. I also bought a set of 5, and the best 4 are on the truck, according to the tire guy.
    The stock raptor tires would be smaller than these i think? likely easier to balance? not sure, just guessing.
  7. Jul 19, 2019 at 12:07 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’ve ran bfg’s for years. Always had good luck w them. Last set I had, one would not balance. Ended up getting rid of that truck, last GM I’ll own too.
    Have coopers now, will stick w that brand now.
    Go back to tire shop and see if they’ll change out the 1 or 2 that won’t balance.
    Problem is probably not wit the wheel.
  8. Jul 19, 2019 at 12:28 PM
    BZRK_Tundra
    BZRK_Tundra New Member
    Jon
    2011 White Tundra Crewmax
    7" Lift
    I've had similar issues with my 35" BFG K02's, they've been hell to balance.
  9. Jul 19, 2019 at 12:36 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It's not the wheels... it's the tires.
    jeremyd, Pinay and TheBeast like this.
  10. Jul 19, 2019 at 12:48 PM
    Cement.pro
    made an appointment for Tuesday next week to have them balanced again. If that doesnt do the trick, new tires will be going on to test that. If new tires doesnt fix it, PART OUT ;)
  11. Jul 19, 2019 at 12:59 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    If it’s discount tire they’ll let you swap them out or even change brands.
    HappyGilmore likes this.
  12. Jul 19, 2019 at 6:41 PM
    TXTundra2722
    2015 Black Tundra
    The Raptors are pretty much running 35s. I think is 315/70/18, whatever is almost identical to the 35
  13. Nov 12, 2019 at 4:49 PM
    Shaggie13
    Shaggie13 New Member
    Mitch
    Central CA
    2017 TRD Pro Tundra Superwhite
    Fifteen52 wheels, rolling on tires.
    So, what ending up happening? Did the shaking finally quit?
  14. Nov 12, 2019 at 5:51 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    315/70/17 ~ 35x12.50x17.
  15. Nov 12, 2019 at 5:53 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    What are they considering out of round?
    For a car tire I consider out of round if it has over 20 pounds of road force. For a truck tire it's 40 pounds.
    Are you running extended thread lug nuts with the wheels?
  16. Nov 12, 2019 at 6:28 PM
    Cement.pro
    Still shaking. Going to try to get rid of the whole setup shortly here. 5 wheels + 4 tires. Go to 17's, 35's, and something hubcentric.
    Anyone know where the good black friday deals are on wheels?
  17. Nov 12, 2019 at 6:42 PM
    NR-J
    NR-J New Member
    Justin
    2015 white tundra
    I have never owned a set of BFGs that balanced properly.
  18. Feb 24, 2023 at 5:20 PM
    Lamanna33
    Lamanna33 New Member
    Sal
    2022 Tundra SR5
    Just got 18x9 Methods wrapped in 265/70/r18 Falken Wildpeak and I’m experiencing the same exact issue. Been balanced been road forced.
