Method center caps?
Discussion in 'Wheels & Tires' started by DexterL, Jul 20, 2019.
  1. Jul 20, 2019 at 7:01 AM
    DexterL
    DexterL [OP] New Member
    21 lunar rock TRD pro Seqouia
    I just tried searching but couldnt find anything, I remember seeing a few folks who had customized their method wheels center caps for a more flush, clean look. Anyone have the info? Thanks!
  2. Jul 20, 2019 at 7:13 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I did it to mine, not the easiest thing ever to do. EC0C07FC-9E17-4FFC-B474-72EFA4288A72.jpg427FCB93-FF33-42FE-9703-C9D1C8309709.jpg74316DBB-3938-41D1-A878-B6231821BF2F.jpg
    I’m working on putting a center cap off of a roost on them now. I have the 306 Mesh by the way.
    JoshuaA likes this.
  3. Jul 20, 2019 at 8:18 AM
    DexterL
  4. Jul 20, 2019 at 8:35 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
  5. Jul 20, 2019 at 9:26 AM
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
  6. Jul 20, 2019 at 10:07 AM
    Omohundro
    Jody
    McMinnville TN
  7. Jul 20, 2019 at 11:45 AM
    DexterL
    I ordered the NV’s in bronze
  8. Jul 25, 2019 at 6:56 PM
    DexterL
    Doesn’t work unfortunately!
    OR18TRD likes this.
  9. Jul 25, 2019 at 10:34 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    Check out chief machining....
    Pricey but custom billet flush center caps
    Bannock452 likes this.
  10. Jul 25, 2019 at 10:45 PM
    rallypanam
    rallypanam New Member
    2019 Doublecab Limited 4x4
    Wait, did y’all not get method flush center caps? Was I just lucky?
  11. Jul 26, 2019 at 8:04 AM
    DexterL
    Those only work with certain wheels. Going to run mine without caps, at the tire shop as we speak getting them mounted up
  12. Jul 26, 2019 at 8:20 AM
    rallypanam
    Lucky me.
  13. Jul 26, 2019 at 11:28 AM
    DexterL
    They look pretty damn good without center caps!
    Omohundro likes this.
  14. Feb 8, 2020 at 10:13 AM
    SLOWER
    SLOWER New Member
  15. Dec 4, 2020 at 2:26 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    How did you put the flared bottom on that shorter center cap? What material did you use?
  16. Dec 4, 2020 at 3:14 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Might need a set of flush mounts for my double standards :monocle: that’d be clean
  17. Dec 5, 2020 at 4:45 PM
    Omohundro
    Jody
    McMinnville TN
    Made the flange out of some 3M 2part panel bond, it was a pain in the rump.
    Bob_Wiley[QUOTED] likes this.
  18. Dec 5, 2020 at 4:50 PM
    Omohundro
    Jody
    McMinnville TN
  19. Dec 27, 2020 at 10:50 AM
    schosports
    schosports New Member
    BIll
    Bel Air, MD
    2014 CM
  20. Dec 27, 2020 at 10:52 AM
    Omohundro
    Jody
    McMinnville TN
    Our bolt pattern is not listed so I don’t think it’s offered.
    schosports[QUOTED] likes this.
  21. Dec 27, 2020 at 5:38 PM
    schosports
    BIll
    Bel Air, MD
    2014 CM
    Yeah didn’t see our 5x150 on there but figured I’d ask them anyway. Come Spring I might be trying to make my own like you did.
  22. Apr 5, 2022 at 11:12 AM
    Joshtinoco
    Joshtinoco New Member
    I went ahead and hut up method wheels, they added the Flush hub caps for my 305’s that are push through. Part number CP-TOPO127P-B, 5x150. Will be ordering them. Hope this will help. I’ll post pics once they arrive.
    Flyinryank and Bob_Wiley like this.
  23. Aug 15, 2022 at 12:08 AM
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Ever get these? I hate the center caps I have but don’t feel like dropping $150 without seeing someone with them.
    Flyinryank likes this.
  24. Aug 15, 2022 at 12:40 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Way better IMO than the long ass caps they come with. Easier to clean too even though they’re dirty af right now
    Dirtnap and Bob_Wiley like this.
