Meso Customs Ultimate Dome and Map Lights
Discussion in 'Lighting' started by 713Tundra, Feb 10, 2022.
  1. Feb 10, 2022 at 7:55 PM
    713Tundra
    713Tundra [OP] New Member
    HTX
    2017 BBP Limited TRD OR CM
    So, I recently ordered and the Meso Customs ultimate dome and map lights set. Unfortunately, I've already trashed the factory incandescent bulbs. I noticed something and was just wondering if it was only me that it's happening to or if it's a result/consequence of installing these lights. Anyways, when I set the map and dome lights to "DOOR" to come on when a door opens, it no longer turns on. They do come on when I set the switch "ON" and turn off when I set to switch to "OFF". I was just curious if anyone else was having the same occurrence.
  2. Feb 10, 2022 at 8:02 PM
    Enjoihavok
    Enjoihavok New Member
    Erik
    Chandler,AZ
    Mine work just fine on door, not super helpful, but sounds like yours is having an issue of some sorts.
    Taco-Spike likes this.
  3. Feb 11, 2022 at 6:24 AM
    Taco-Spike
    Two Trucks
    Mine is fine in both Tacoma and Tundra.
    I agree with above, something is screwy.
    Just curious, did you disconnect the battery when you installed? Some trucks act differently to these things so it can get hard to pin point.
    Also, I did not disconnect mine, or remove the entire map / dome assembly, just removed the lens cover.
  4. Feb 11, 2022 at 6:03 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    have read recently on here that you can modify the dome light setting on the head unit by going to settings then auto and there should be the dome light settings. I think you can set the time the lights are on including setting the time to off. A reset can happen when you disconnect the battery.
    bulldog93 and 713Tundra[OP] like this.
  5. Mar 1, 2022 at 7:56 AM
    Bummy11
    Bummy11 New Member
    ^^^This. Because I disconnected the battery to do the install, light setting was reverted to off. Changed it to 30 sec and all is good.
    bulldog93 likes this.
