MAXTRAX MKII - The Ultimate Traction & Recovery Device
Discussion in 'MAXTRAX' started by MAXTRAX, Jun 12, 2018.
  1. Jun 12, 2018 at 9:29 AM
    MAXTRAX
    MAXTRAX [OP] us.MAXTRAX.com.au
    This thread discusses the MAXTRAX MKII. Post up any questions you have, photos, feedback, etc.
    We want to see your your MAXTRAX in action!
    MAXTRAX MKII
    https://us.maxtrax.com.au
    MAXTRAX is the lightweight, easy-to-use vehicle recovery and extraction device that’s easily carried by almost anything with four-wheels ensuring an easy way out if your vehicle becomes stuck. MAXTRAX takes the drama out of getting stuck. The aggressive large cleats on MAXTRAX sink their teeth into the tire tread and the terrain under your 4WD vehicle to prevent it from slipping back into mud, snow, or sand and make vehicle recovery quick and easy.
    MAXTRAX is the perfect fit for every outing. Measuring just 45 inches long X 13 inches wide, each set of MAXTRAX stacks together at a height of just 3.5 inches. MAXTRAX stows easily with the rest of your car camping, overlanding, or four-wheel drive gear. MAXTRAX is also easy to carry! MAXTRAX have six comfortable built-in handles and a shovel at either end for removing excess earth to help get you unstuck quicker. They also have exclusive keyhole accessory points to allow you to securely mount your MAXTRAX.
    Made of UV-stabilized, flexible, super tough engineering-grade reinforced nylon, MAXTRAX provides traction and a firm base to get your vehicle quickly back on track. They have been tested at the University of Queensland to wrap completely around a 33-inch tire without breaking.
    The MAXTRAX MKII is available in a variety of colors, take a look at some of the great options we offer:
    https://us.maxtrax.com.au/product-category/maxtrax/
    MAXTRAX
  2. Jun 12, 2018 at 9:52 AM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Here is my setup:
    Only running two maxtrax right now, but considering adding another two. Super easy to put on and off with the Front Runner Outfitters Mounting Kit. Ran a cable lock through and around my crossbars to help prevent theft. Not too worried since it sits in the garage mostly.
    Only ONE TIME have I gone out without them (BD was using the company ones at the time)... and it was with @TOTAL CHAOS who also left every single set back at the shop. The plan was to do some minor wheeling and get some photos at Crowley Lake... Ended up burying the FJ, Tacoma, and Tundra
    :D
    Sunnier, sdde4n, jewsNbrews and 3 others like this.
  3. Jun 12, 2018 at 11:25 AM
    TOTAL CHAOS
    TOTAL CHAOS WWW.CHAOSFAB.COM Vendor
    Corona, CA
    :mudding:
    Now most TOTAL CHAOS shop vehicles keep sets mounted, locked, and ready to rock.
    You can see 3 vehicles with them below. Platinum Tundra and Morocco Taco have some mounted in the bed, but you can't see them from this angle
    jewsNbrews and Cemented like this.
  4. Jun 12, 2018 at 11:51 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Need a vendor in Canada who can source stuff out.
    Having a hard time tracking down a competent vendor via the Google search.
    Looking to get a set or two shortly.
    Welcome btw.
    jewsNbrews likes this.
  5. Jun 12, 2018 at 12:14 PM
    MAXTRAX
    Here are two options for you:
    Overland Outfitters
    www.overlandoutfitters.ca
    778-547-2444
    5828 176 ST Surrey, BC V3S 4E2
    Kakadu Camping
    https://www.kakaducamping.com/
    604-277-5252
    Unit 103B, 8257 92nd St. Delta BC V4G 0A4
    Thank You for your interest in our products :thumbsup:
  6. Jun 12, 2018 at 1:03 PM
    Krezz
    Kevin
    Excellent - thank you very much!
  7. Jun 18, 2018 at 7:28 AM
    MAXTRAX
  8. Jun 25, 2018 at 12:12 PM
    MAXTRAX
    MAXTRAX Mounting Accessories
    https://us.maxtrax.com.au/product-category/mountingaccessories/
    Have a rear mounted spare tire that you want to mount MAXTRAX to? Looking to lock your MAXTRAX to your roof rack our mounting surface? We offer two mounting accessories on our site geared to aid in securing your MAXTRAX.
    MAXTRAX - Rear Wheel Harness
    The MAXTRAX Rear Wheel Harness lets you safely and securely carry your MAXTRAX on your vehicle’s rear-mounted spare tire. Quick and simple to install, the harness makes it easy to quickly grab your MAXTRAX when you need them in a hurry and means you can carry dirty ones without dropping sand, mud or snow in or on your vehicle.
    The harness will carry up to 5 MAXTRAX (or 4 really dirty ones that won’t stack together neatly) and includes a pouch to hold your fixing pegs and linking straps.
    *PLEASE NOTE: The MAXTRAX Rear Wheel Harness is designed to suit vehicles where there is easy access behind the spare wheel mount, typically with an aftermarket swing away carrier or rear bar such as Kaymar. * Designed for MAXTRAX MKII only. (MAXTRAX NOT INCLUDED).
    AVAILABLE HERE
    MAXTRAX - Mounting Pin Set
    Genuine MAXTRAX Mounting Pins are the easiest, safest, and most secure mounting solution for putting your MAXTRAX on a roof rack or cross-bars. Constructed from high-quality black nylon and stainless steel, these quick-release pins can hold one or two sets of MAXTRAX (2 or 4 boards).
    Top roof rack manufacturers, including Rhino Rack, Eezi-Awn, Front Runner, and more, make a reciprocal bracket that allows for a bolt-on roof rack mounting solution.
    Designed exclusively for MAXTRAX MKII—these cannot be used with any other brands.
    AVAILABLE HERE
    MAXTRAX
    us.maxtrax.com.au
    Erichudgins and Sunnier like this.
  9. Jun 26, 2018 at 3:32 PM
    MAXTRAX
    Erichudgins and jewsNbrews like this.
  10. Jul 1, 2018 at 8:24 PM
    MAXTRAX
    Hope everyone enjoyed their weekend. We are closing up at NW Overland Rally and can't wait for the next event. See you at FJ summit later this month
    MAXTRAX
  11. Jul 2, 2018 at 12:29 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    How do you get a single maxtrax mount? My wife gave me a pair of maxtrax for fathers day. I purchased a set of mounts. One mount the bolt went halfway down and then stopped. I can't get the bolt off. I am going to have to cut the bolt off and the mount is now bent from me trying to get it off. The other three went on easy, it was one that I have a problem with.
  12. Jul 2, 2018 at 4:29 PM
    MAXTRAX
    Sorry about the issue. You just need one mounting pin, correct?
    Send us a PM with your shipping and contact info and we'll be in touch shortly
    MAXTRAX
    Sunnier, jewsNbrews and Erichudgins like this.
  13. Jul 3, 2018 at 12:13 PM
    Grendel
    Grendel New Member
    Thanks for your quick reply. PM sent.
  14. Jul 10, 2018 at 2:12 PM
    MAXTRAX
  15. Jul 13, 2018 at 4:12 PM
    MAXTRAX
    Sunnier likes this.
  16. Jul 18, 2018 at 10:11 PM
    Swamp_Dawg
    Swamp_Dawg New Member
    Greg
    2012 Silver Tundra TRD
    Four Wheel Pop Up Camper, Aluminess Ft Bumper, Warn VRS-12000 winch, KC 20” light bar, Bushwacker fenders
    Max Trax. Great product. Have 2, about to buy 2 more. Had a custom rack made to hold 4. A must have for our trips.
    Bailey, T-Rex266, 831Tun and 2 others like this.
  17. Jul 18, 2018 at 10:42 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Details on the rack...?
  18. Jul 19, 2018 at 2:11 PM
    Bailey
    CO
    That setup is sweet ^
  19. Jul 23, 2018 at 10:25 PM
    Swamp_Dawg
    Greg
    My son had a local metal company fab a rack from a drawing and measurements of his 4 Maxtrax’s for a swing arm. I just bolted mine on my camper, added the straps and it was pretty easy. Handy when I need them. As of now, I’m able to hold my shovel as well.
  20. Jul 24, 2018 at 12:51 AM
    Sunnier
    Sunny
    San Diego, CA
    We love pictures....
  21. Aug 9, 2018 at 8:47 AM
    MAXTRAX
    Krezz and Sunnier like this.
  22. Dec 30, 2018 at 9:35 AM
    Krezz
    Kevin
    To this happened a moment ago...
    Your order is confirmed
    You’ll receive a confirmation email with your order number shortly.
  23. Dec 30, 2018 at 9:37 AM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    Nice! Congrats, sir. You'll be so stoked with these.
    Krezz[QUOTED] likes this.
