MAXTRAX Lockable Mounting Pins
Discussion in 'MAXTRAX' started by MAXTRAX, Jul 17, 2018.
  1. Jul 17, 2018 at 12:23 PM
    MAXTRAX
    MAXTRAX [OP] us.MAXTRAX.com.au
    Genuine MAXTRAX Mounting Pins are the easiest, safest, and most secure mounting solution for putting your MAXTRAX on a roof rack or cross-bars. Constructed from high-quality black nylon and stainless steel, these quick-release pins can hold one or two sets of MAXTRAX (2 or 4 boards).
    Designed exclusively for MAXTRAX MKII—these cannot be used with any other brands.
    Learn More
    MAXTRAX
    https://us.maxtrax.com.au
  2. Jul 17, 2018 at 3:12 PM
    Sunnier
    Sunny
    San Diego, CA
    Free shipping for forum members, as for the MaxTrax?
  3. Jul 18, 2018 at 5:20 PM
    MAXTRAX
    MAXTRAX ship FREE to the U.S. :oldglory:
    Code: maxtraxforums2018
  4. Jul 18, 2018 at 5:29 PM
    Sunnier
    Sunny
    San Diego, CA
    Yes, I know MaxTrax do! I've got a set I've used to self-rescue twice and love 'em!!
    Does the free shipping cover the attachment pin hardware too, if not purchased at the same time as MaxTrax (for those of us that already have the MaxTrax)?
    831Tun likes this.
  5. Jul 18, 2018 at 5:34 PM
    MAXTRAX
    Oh sorry - I was a little confused with your question.
    These do ship FREE as well with the same coupon code.
    Sunnier[QUOTED] and 831Tun like this.
  6. Jul 18, 2018 at 6:35 PM
    Sunnier
    Sunny
    San Diego, CA
    Well then, Amazon Prime Day wasn't the end of this week's :spending:. Thanks!
  7. Aug 22, 2018 at 1:08 PM
    MAXTRAX
    MAXTRAX - Mounting Pin Set Instructions
    Please follow the instructions on this page carefully when fitting and using the official MAXTRAX Mounting Pins.
    Note 1. Manufacturing tolerances (of +/-1%) may affect these dimensions slightly so please check these dimensions against your MAXTRAX before drilling. As a safety measure, the pins SHOULD be mounted vertically so that the MAXTRAX are carried horizontally.
    Note 2. You will need to trim 15mm off the thread for use in channel-type roof bars.
    Note 3. Ensure pins are aligned so that the padlock hole in the top 'knuckle' is visible once the MAXTRAX are locked down.
    Note 4. For additional security, fit a small padlock through the most easily-accessible mounting pin. A wire combination padlock is the best option (they are readily available and you can't lose the key!).
    MAXTRAX
    Sunnier likes this.
