Maximum weight rear axle can take
Discussion in 'Suspension' started by NeilToyota, Sep 5, 2022.
  1. Sep 5, 2022 at 5:55 PM
    NeilToyota
    NeilToyota [OP] New Member
    Neil
    2002 Tundra 4.7L V8 Access Cab
    Bilstein B6 Heavy Duty Shocks AirLift Rear Leveling Airbags
    How much over the rear axle GAWR
    Do you think an axle could take on a 2002 RWD Toyota tundra? Thanks. Neil
  2. Sep 5, 2022 at 6:37 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    It’s on the door sticker, but I believe the rear GAWR is around 3860 lbs for a 2WD.
  3. Sep 5, 2022 at 6:47 PM
    NeilToyota
    Neil
    Thanks. Someone I talked to said that they thought you could go almost 3000 pounds over the recommended weight. What do you think? Sounds a little crazy to me.
  4. Sep 5, 2022 at 7:02 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    It’s a semi-floating design. Probably not a whole lot more than its rating.
  5. Sep 5, 2022 at 7:22 PM
    NeilToyota
    Neil
    Okay. Thanks. That’s kind of what I was thinking.
  6. Sep 5, 2022 at 7:23 PM
    mountainpete
    The trouble with Toyota trucks is the massive gap between what you can do and what you should do.
    Payload is one of the areas where the truck is generally considered low but capable of so much more. Unfortunately there is no legal way in North America to increase the GVWR of a non-commerical truck.
  7. Sep 5, 2022 at 7:32 PM
    NeilToyota
    Neil
    I tend towards safety and don’t want to push it. Thanks!
  8. Sep 5, 2022 at 7:34 PM
    NeilToyota
    Neil
    I was hoping that the Bilstein B6 shocks and 10 ply tires and rear airlift airbags would make it better. In fact, I’m pretty sure it made it better, but not necessarily safe.
  9. Sep 5, 2022 at 8:13 PM
    Retired...finally
    Sounds like a loaded question.
    mountainpete and hagrid like this.
  10. Sep 5, 2022 at 9:17 PM
    Same axle that’s in a Tacoma is it not?
    Think that covers that topic. :thumbsup:
    Retired...finally likes this.
  11. Sep 6, 2022 at 2:58 AM
    NeilToyota
    Neil
    Don’t know what axle is in the Tacoma.
  12. Sep 6, 2022 at 2:58 PM
    NeilToyota
    Neil
    I was told the 10 ply tires are a lifesaver.
  13. Sep 6, 2022 at 3:14 PM
    Way overkill to have a rough riding truck.
  14. Sep 6, 2022 at 3:40 PM
    NeilToyota
    Neil
    They said 10 ply tires would be good if you’re putting an RV truck camper in the back
  15. Sep 6, 2022 at 3:47 PM
    Most likely would be overweight anyway unless you get one of those super duper light ones that don’t offer much.
  16. Sep 6, 2022 at 3:52 PM
    NeilToyota
    Neil
