Max Wheel / Tire Size
Discussion in 'Wheels & Tires' started by IowaTundraGuy0714, Sep 21, 2021.
  1. Sep 21, 2021 at 1:39 PM
    IowaTundraGuy0714
    IowaTundraGuy0714 [OP] New Member
    Jerrad
    2017 White Tundra Limited Crewmax
    Pretty much stock at this point, but just getting started.
    I have a 2017 Limited Crewmax that I have just purchased this summer. Haven't gotten around to a lot of upgrades yet, but it is in dire need of some new tires before winter. Once it's lifted (thinking anywhere from 3.5" to 6"), I plan on running some 35x12.50R22's during the summer & my stocks in the winter. I don't want it to look to strange when running the stocks, so wondering how big a tire I could currently fit (pre-lift) that will still look okay when it's raised. Was thinking maybe 33x12.50R20's with 1.5" spacers. What do y'all think?
  2. Sep 21, 2021 at 1:53 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    33x1250s are wide, add spacers and you will have contact - wheel liner, maybe body mount, front bumper. Those issues can be addressed however.
    If you are running stock wheels you can fit 275/70-18 or 285/70-18 on a stock truck, no lift with no fuss. If you address some of the rubbing on plastics, you should be able to fit 295/70-18 on a stock truck.
    Check out the suspension and wheel/tire forums here for tons of good info, pics, setups, etc. Use this tool to better understand metric LT tire sizes vs inches
  3. Sep 22, 2021 at 7:12 AM
    IowaTundraGuy0714
    Jerrad
    Thanks for the heads up. My limited has the machined 20" wheels on it, so won't be doing any 18's. Thought that by adding the spacer I may have a little more room to move...no? According to the tiresize.com calculator, I'm only adding 1.1" in overall diameter & obviously 1.7" in width.
