Max tire size.
Discussion in 'Wheels & Tires' started by Rockstar72, Oct 12, 2023.
  1. Oct 12, 2023 at 7:19 AM
    Rockstar72
    Rockstar72 [OP] New Hampshire in the house
    Kris
    Manchester, NH
    2020 Army Green Toyota Tundra TRD Pro Crewmax
    Sorry if this has been asked before. I just put adjustable struts(to level it) in the front of my 2016 Toyota Tundra Limited and new rear shocks (no lift at all). A coworker who is an ex-Tundra owner said he put 35s on his leveled Tundra but had to use spacers. Is this possible?
  2. Oct 12, 2023 at 9:34 AM
    35's on a leveled truck is tough. Every truck sits at a different height. One of the biggest factors is the wheel offset.
  3. Oct 12, 2023 at 10:04 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    +1
    Though if all you're doing is have it leveled, all it needs is trim the bumper just a little.
    Alignment can help a ton to keep the tire from rubbing the inner fender/cab mount.
    Rockstar72[OP] likes this.
  4. Oct 12, 2023 at 10:08 AM
  5. Oct 12, 2023 at 10:11 AM
    2020cement_tundra
    2020cement_tundra New Member
    Nick
    SC
    2020 tundra
    Just remember though, just because it may fit doesn’t mean your truck will drive well, towing if you do that will suck as will mileage
  6. Oct 12, 2023 at 10:12 AM
    2020cement_tundra
    Nick
    SC
    2020 tundra
    I leveled my 2020 and went to 33’s and could tell I could only imagine how the 35 would act
  7. Oct 12, 2023 at 10:25 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    You appear to have the 18" factory TRD wheels, I have Bilstein 6112's at 1.9" and run 295/70r18 with no rubbing, no modifications (removed little flaps hanging from front bumper), no wheel spacers.
  8. Oct 12, 2023 at 1:42 PM
    Rockstar72
    Kris
    Manchester, NH
    I was thinking of 295/70R18. I have the stock 275/65R18 on it now so that would be a little bump. Thank you for all the great info.
  9. Oct 12, 2023 at 3:54 PM
    Rngr188
    Chad
    Harrison AR
    I ran 275/70r18 prior to this set and they were fine also, also ran that size on my 17 bone stock.
