Max size combo of tire, wheel, offset, width, etc. that WILL NOT stick out past the fender?
Discussion in 'Wheels & Tires' started by cthomaschase, Feb 14, 2017.
  1. Feb 14, 2017 at 4:07 PM
    cthomaschase
    cthomaschase [OP] New Member
    I've read pages and pages of posts and can't find an answer, sorry if this is redundant.
    I put a Bilstein 6112/5160 setup at max lift 2.5" in front. Time for wheels and tires. I've looked all over and can't find a clear answer...
    I want to buy new tires and wheels. Wheels most likely will be 18", we'll see. I'd like tires that fill the well nicely, however, I don't want them sticking too far out from the fender. I honestly have no clue what offset to get, what size tire, etc.
    Is there a way to know the max size combo of tire, wheel, offset, width, etc. that WILL NOT stick out past the fender?
  2. Feb 14, 2017 at 4:20 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Not sure what gen truck you got, but my guess would be like OEM and go with a +60. I'm sure some of the other savants on this thread will have a much better detailed answer for you.
  3. Feb 14, 2017 at 4:37 PM
    TheBeast The Beach
    18" with +18 offset and 12.5" wide: they slightly stick out past the fender
    cthomaschase[OP] likes this.
  4. Feb 14, 2017 at 4:58 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you don't want to stick out at all, you have to go with +50 to +60 on a max width of 9" wheel. 8" width might be better.
  5. Feb 14, 2017 at 5:11 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    If you want to stay with a OEM alloy wheel, you can get away with a 285/75R-18. That's equal to a 35x11.50. Will need some mudflap mods etc, but will stay completely inside the fenders. If you look at my build thread, most pics are with the 285, but some have been updated to the 37's I have on now. Hope this helps, and I know one of the most popular sizes on here is 295/70-18. Good luck with all.
  6. Feb 14, 2017 at 5:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Here's a very basic offset calculator. Just enter your current and new width and offset and it'll tell you how much more it'll stick out. Remember 25.4mm = 1 inch.
    mquimby and CM-LENNY like this.
  7. Feb 14, 2017 at 5:55 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    35x12.50x18 on a 9" wide whee with +18 offset. If you went with a +25 offset you would basically be level with the fenders.
  8. Feb 14, 2017 at 5:57 PM
    cthomaschase
    This is helpful, thanks!
  9. Feb 14, 2017 at 6:35 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    I'm pretty stupid with this offset stuff. I have the TRD OEM wheels, and I wanted to throw on the 1.25 spidertrax adapters. What offset would that be sitting at?
  10. Feb 14, 2017 at 6:39 PM
    CM-LENNY
    San Diego, CA
    Just do the good ol math. 25.44 x 1.25 = total mm. Subtract that from your starting point of 60mm. Approx 28mm offset.
    joonbug and Spolar[QUOTED] like this.
  11. Feb 14, 2017 at 6:44 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Thanks brotha. I had never even bothered to figure out what the stock offset of the TRD wheels are...
  12. Feb 14, 2017 at 7:02 PM
    CM-LENNY
    San Diego, CA
    No worries Zac. Didn't mean to come off like an ass. Like Joon said earlier, just remember 1"=25.44mm, and you can get just about any idea of what offset you will be looking at. Another thing, hold a straight edge against your tire or fender and that gives you a good reference point.
    Jsena, jberry813 and zcarpenter92 like this.
  13. Feb 14, 2017 at 8:03 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Believe me you didn't come off as anything but helpful!
    CM-LENNY[QUOTED] likes this.
  14. Feb 14, 2017 at 8:10 PM
    chphilo
    chphilo Tundra addict
    Western PA
    For the most popular width (9 inches), it seems 30-35 mm seems to be most rubbing-free. Higher offset you may rub some suspension components if you go with wide tires. Lower offset may cause rubbing at the body mount. I've seen some guys with 35 inch tires with Bilstein 5100 and 30 mm offset wheels as I remember.
    Also if you do not wish to have your tires stick out too far, stay in 30-35 mm range. My 18 mm offset wheels make the tires to poke out quite a bit. My tires are roughly even with Bushwacker pocket style fender flares.
  15. Feb 15, 2017 at 6:27 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    What @chphilo said...typically somewhere in the +30 range will keep you even with the fenders. IMO, sticking out just a little does look better though; sure, you're truck gets a little dirtier, but it's a more aggressive stance that looks great. I'm on a +18, so no need to post another picture (see @jberry813 above). A happy middle ground would be a +25 offset on a 9" wheel
  16. Feb 15, 2017 at 8:14 AM
    cthomaschase
    Thanks for all the feedback. Maybe I'll put flares on...hadn't really thought of it until now.
  17. Feb 23, 2017 at 10:01 PM
    TMMTX
    TMMTX New Member
    None
    I was doing research for the exact same thing...wheels and tires but for a 20" wheel. I was thinking of doing a +25 OS, but yours looks almost exactly what I envision in my head. So it looks like I need to do something more like a 18-20 positive offset.
    And the fact that you have a 35" wheel! I was thinking of doing a 305/55/20, which should be somewhere in the vicinity of a 33x12x20. Did you have to worry about any trimming or anything?
  18. Feb 24, 2017 at 3:27 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Whatever you getting, buy some OEM fender flares to tone it down. See my pics below.
    Jsena and cthomaschase[OP] like this.
  19. Feb 24, 2017 at 7:19 AM
    jberry813
    Lake Tahoe
    Nothing you cant fix with a cutoff wheel.
    Trim an inch off the skid plate, remove the front mudflaps, remove the front lower plastic apron, and do a cab mount chop.
    zcarpenter92 and CM-LENNY like this.
  20. Apr 25, 2017 at 5:30 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What size wheels and offset and tire sizes in this pic
  21. Apr 25, 2017 at 5:54 PM
    Les7311
    They are 20 x 35's
    I really cannot tell the offset I would have to pull receipt
    Jsena[QUOTED] likes this.
