Matte Black Lugs
Discussion in 'Wheels & Tires' started by Atl626, Jun 10, 2018.
  1. Jun 10, 2018 at 6:44 PM
    Atl626
    Atl626 [OP] New Member
    2018 black Crewmax SR5
    I am looking for some recommendations on black lug nuts, i am powder coating my wheels matte black and would like the lug nuts to match, am i better off powder coating my lug nuts or is there a quality aftermarket lug nut that will work....thanks in advance
  2. Jun 10, 2018 at 7:13 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Spline lugs are what I’m looking at. About $45 for set of 20 with the tool. I sprayed lugs a long time ago and they pretty much go to crap once you put them back on.
  3. Jun 11, 2018 at 9:54 AM
    PMG
    PMG New Member
    any recommendations for one that won't rust after one freaking winter?
  4. Jun 11, 2018 at 10:02 AM
    Grumpy Uncle
    Pat
    CO
    So far I have been through 2 sets of lugs. I wont be spending anymore money. I thing next time I'll try some rust inhibitor and rustoleum.
    Edit: spending money on lugs.
    Black Wolf and 4x4_Angel like this.
  5. Jun 11, 2018 at 10:06 AM
    BayRunner
    2017 Tundra Platinum
    I just used ColorLugs myself to cover the existing lugs. Cheap and can just keep existing lugs.
    www.colorlugs.com
  6. Jun 11, 2018 at 10:09 AM
    Grumpy Uncle
    Pat
    CO
    BA! might have to get some.
    4x4_Angel likes this.
  7. Jun 11, 2018 at 10:41 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    On my previous SCS wheels I went through two sets of black lug nuts and nothing lasts beyond one tire rotation before they start surface rusting. Gorilla nuts and the spline nuts from Vin@SCS, didn't matter, rust ensued. I don't even use the impact, only hand tools on the lugs. Only thing that doesn't seem to rust no matter the abuse are the stock chromies.
    My only solution to the black was to clean them well and repaint rattle can them as needed.
  8. Jun 11, 2018 at 10:53 AM
    Grumpy Uncle
    Pat
    CO
    How long do they last before UV and road grime starts to break them down? Maybe a better question, how long have you used them? Not troubleshooting you, just curious because I'm really interested.
  9. Jun 11, 2018 at 10:59 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    +1^^^^^
  10. Jun 11, 2018 at 11:41 AM
    BayRunner
    I've had them on for about 7 months now. Have had then off several times for tire rotations, mod installs, etc and they still look new. Highly recommended
  11. Jun 11, 2018 at 11:42 AM
    Juddrussell
    Juddrussell New Member
    Jacob
    Bentonville, AR
    2016 MGM Tundra TRD Pro
    BAMF Bedrack, 295/70/r18 General Grabbers, Bedslide, Weathertech floor mats, and Tepui Autana Sky RTT.
    I believe @Watt maker is running the color lugs as well?
  12. Jun 11, 2018 at 11:51 AM
    Grumpy Uncle
    Pat
    CO
    Cool, thanks..
  13. Jun 11, 2018 at 11:56 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    You can also get any lug nuts you want powder coated matte black. Two things to consider. If they powder coat them very thick they may be a tight fit onto the socket. If they are removed with an impact wrench they tend to chip the paint or powder coat on the edges and lead to rust.
  14. Jun 11, 2018 at 1:43 PM
    PMG
    PMG New Member
    Problem is I'm in Chicago and we have horrible salt in winter (shootings everyday) and wheels get rotated every 5k with an impact.
  15. Jun 11, 2018 at 3:15 PM
    BayRunner
    The LugCap 21-23 mm
    NewImprovedRon likes this.
  16. Jun 11, 2018 at 3:32 PM
    Rolodetective
    Rolodetective Member
    Vale of Paradise, Indiana
    2004 Black AC TRD
    +2 Colorlugs for the win!
  17. Jun 11, 2018 at 3:51 PM
    Atl626
    Thanks for all the imput , looks like color lugs is the way to go, i think i will order a set of OEM lug nuts and cover them.
  18. Jun 26, 2018 at 4:40 AM
    Atl626
    I went to order some and they list 2 that are 21-23 mm , do i need the lug cap or lug sleeve? i will be using the stock lug nuts that came with my steel wheels, im hoping those lug nuts will work on my trd wheels
    thanks in advance
  19. Jun 26, 2018 at 5:01 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I believe the lugs for the steel wheels are a different length. You may want to measure them. Also you can trim them to size with scissors, so if in doubt, go longer.
  20. Jun 26, 2018 at 6:40 AM
    BayRunner
    I don't know about the lugs for the steel wheels, but the lugs for my TRD Pro wheels used the LugCap 21-23 mm.
  21. Jun 26, 2018 at 6:41 AM
    BayRunner
    Your welcome. Glad you like them.
  22. Jun 27, 2018 at 3:54 PM
    What the!?
    What the!? New Member
    2017 Pro
    I got the colorlugz for my stock lugs also. Customer service was great. I didn’t realize the oem wheel locks were a bit larger that the oem lugs. I emailed them to order new ones to fit and they sent them to me free. It’s customer service like that that will keep me buying from them!
  23. Jun 27, 2018 at 7:26 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Gorilla lugs are high quality and can be purchased in black. I have a set and they are better made than oem.
  24. Oct 14, 2020 at 3:52 PM
    house
    house I blame you guys for my mod spending
    2019 MGM CM Limited 4x4
  25. Nov 2, 2020 at 3:13 PM
    2planker
    2planker New Member
    think I'm gonna give gorilla a try, just got some methods and they came with chrome lugs :mad: customer service rep at method told me they shouldn't have come with any lugs and i should be grateful i got a freebie from the tire rack. i've bought other custom wheels in the past for other vehicles BBS, Sparco and they came with matching lugs, guess method has gone the way of apple and is charging you extra for something that should be included when you spend a $1K, its a nickel and dime world out there.....ok enough ranting for the day
  26. Nov 2, 2020 at 3:22 PM
    Blueknights75
    Ron
    Clayton, NC
  27. Nov 3, 2020 at 7:23 AM
    Tundradrenalin
    Virginia Beach, VA
    Most aftermarket wheels don't come with lugs. Except maybe ProComp? But PC also sells lugs. Which is what I'm using on my Methods.
  28. Nov 3, 2020 at 12:31 PM
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    If I powder coat my wheels I will be going with the ones from Toyota.
  29. Nov 17, 2020 at 7:31 AM
    maxdriver
    I just ordered a black OEM set from my local dealer. I have noticed there are several online vendors that are mentioned on the forums. I find the listed price looks great, but then you add in a healthy shipping charge it works out to be about the same...just saying.
