Master warning light??
Discussion in '2.5 Gen Tundras (2014-2021)' started by Acaps, Jan 31, 2020.
  1. Jan 31, 2020 at 7:23 PM
    Acaps
    Acaps [OP] New Member
    Tundra Platty 2020
    Truck is less than a month old (2020 platinum cm). Driving home tonight and master warning light went off along with a constant buzzer?? Any ideas?
  2. Jan 31, 2020 at 7:32 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    What is the master warning light? There are like 73 different lights that could go off. 73 is an exaggeration but it is a lot. Got pics?
  3. Jan 31, 2020 at 7:53 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Warranty, take it to the dealer.
  4. Jan 31, 2020 at 7:57 PM
    Acaps
    Tundra Platty 2020
    Yellow exclamation point inside a triangle right side of cluster. Blinks and a constant buzzer sounded. Didn’t go off till I shut off truck
  5. Jan 31, 2020 at 8:04 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Master warning light[1]
    Follow the correction procedure.
    After taking the specified step to correct the suspected problem, check that the warning light turns off.
    Warning light/details:
    A buzzer sounds and the warning light comes on and flashes to indicate that the master warning system has detected a malfunction. Consult your Owner‘s Manualfor more information.
    The User Manual does not give specifics as to the "Malfunction". Call dealer in the morning.
    ThatGuy246 and (deleted member) like this.
  6. Jan 31, 2020 at 10:20 PM
    Acaps
    Tundra Platty 2020
    Going in on Minday morning. Shitty, brand new truck.
  7. Feb 1, 2020 at 12:56 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Mine has done this a couple of times. Also the adaptive cruise and pcs were not working. Problem was fog over the camera in front of the rear view mirror. Stopped truck, turned off, cleaned windshield: problem solved.
    BravoDeltaRomeo likes this.
  8. Feb 1, 2020 at 4:01 AM
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    Yikes, curious to find out what that’s all about. The only time I ever seen a light joined with an alarm was when my 2-stroke outboard is way low on oil, a high water alarm from a vessel sinking, a general alarm from a shipboard fire, and when my wife doesn’t put on her seat belt. Doesn’t sound good.
    JohnLakeman likes this.
  9. Feb 1, 2020 at 4:15 AM
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    It’s new, needs to get broken in the whole system that is, just little glitches. Disconnect battery let it sit for a little, look in fuse box make sure all fuses are in tight. Reconnect battery see happens. Any check engine lights on is if so pull or keep truck running put gear in N shut off, restart truck. I believe it’s just system breaking in. Resting it may help with 1 thing I said. Play around with. Still have problems warranty will cover. Make sure grounds are tight too.
    Twinky likes this.
  10. Feb 1, 2020 at 4:28 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Was it snowing out?
    SIMPLYTHETRUTH likes this.
  11. Feb 1, 2020 at 5:10 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    File this under
    Have a 08 tundra, what a pile of junk toyota can kiss my arse.
  12. Feb 1, 2020 at 5:56 AM
    SIMPLYTHETRUTH
    PA
    2020 Cement TRD
    Yes on my wife’s atlas the snow covered sensors and car went wacky. Technology is good but it seems to be muck at the same time. I want to go back to real steel and fine tuning with a screwdriver, and open engine bay knowing what wires go where. Zillions of wires tapping off everything. Wife’s vw open that hood and your like wtf. 4 pos terminals 2 negs, along with some kind of block terminal, what looks like a computer next to the battery. Glad I have a tundra, also vw all toque heads. Nope dealer that bullshi
  13. Feb 1, 2020 at 6:11 AM
    Joe333x
    Joe333x Member
    Boston
    The constant buzzing sometimes is just the parking sensors if they are covered with snow, you can just shut the parking sensors off, it's a button on the dash to the right of the steering wheel.
    focal likes this.
  14. Feb 1, 2020 at 8:52 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Definitely sounds like a "fire onboard the vessel" kind of alarm to me...Yota shudda' gone with that grating klaxon buzzer every second.
    Dealer! DEALER! DEALER!!!
    focal, Twinky and BravoDeltaRomeo like this.
  15. Feb 1, 2020 at 9:13 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    A little bit of an over reaction, don't you think?
    Did you do any research before you bought it? If so, you know it's not a shitty truck. If you didn't, you're an idiot.
    Take it to the dealer, have them fix/reset it and you'll be good to go
  16. Feb 1, 2020 at 9:17 AM
    Acaps
    Tundra Platty 2020
    It’s not the same noise as the parking sensor. When I start up the truck, a picture outline of the entire truck shows up on the display and stays there while the warning exclamation point flashes yellow and the buzzer like warning beeps constantly. I am in California so no snow, and it’s not raining when this happened. Should be broken in, truck has 1K miles. I will take it in on Monday.....reason I’m so pissed is I jumped from Ford F-150 because I had issues with it and went to Toyota due to its good reliability. Not so excited that I gotta take the truck in when it’s freaking brand new.
  17. Feb 1, 2020 at 9:24 AM
    Acaps
    Tundra Platty 2020
    Yes I did do my research, when I purchase a new product I expect it to function properly. Read my post properly......it states that it’s “shitty” that this occurred (is occurring), didn’t say it’s a shitty truck. Idiot is an interesting choice of words to throw out on a forum where someone is looking for help. But then again, you’re behind a keyboard.
  18. Feb 1, 2020 at 9:27 AM
    Twinky
    07 double cab work horse
    Thats completely understandable. I think most of us would agree with you and also be very frustrated. I also think most of us would also agree that if you give the tundra a chance it will win you over.
    I know this doesn't help but being that you got a brand new model you also kinda get the newest features that have a higher chance of having bugs in the system that will need to be worked out.
  19. Feb 1, 2020 at 9:31 AM
    JohnLakeman
    Give the dealer a chance to exorcise all the assembly demons.
    I predict you'll look back a few years from now and realize that you've done nothing to your Tundra but feed it gasoline, routine maintenance, tires, and a battery or two. (That battery one IS coming in the not-too-distant future, so don't be surprised). You may not even remember that time your Tundra's nannies got their panties in a twist, and the dealer had to tweak it. :rofl:
  20. Feb 1, 2020 at 9:39 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    When I read "Shitty, brand new truck". I'm reading the shitty as describing the truck, not the situation. My choice of the word idiot, stands for anyone who didn't research before buying any new vehicle..in this case, you are NOT an idiot, as you did in fact do research on it.
    If you had said "it's shitty this happened", it comes across differently. Too many people lately having one thing go wrong and then they want to throw the towel in and declare the Tundra a POS in a new thread.
    My truck isn't perfect either and I've had warning lights go off that were unexplained and a couple things I'll have the dealer look at when I take it in for service #1.
    Sorry if I came across crotchidy. Hope it all works out for you. Sometimes posts and threads can be misconstrued or taken out of context, depending on where a comma is placed or a word is auto corrected.
  21. Feb 1, 2020 at 4:45 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    I wonder if maybe it’s a camera or TSS connectivity issue.
    My 2018 has been covered in mud and Love Bugs and never faltered.
  22. Feb 10, 2020 at 10:55 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
  23. Feb 11, 2020 at 6:13 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Been over a week since the Monday trip to the dealer. Have you gotten an answer? Interested minds want to know.....
  24. Feb 11, 2020 at 9:54 PM
    Acaps
    Tundra Platty 2020
    Yes......they said it was a bad hood latch that triggered it. Kinda weird, but they fixed it and flawless since. Very happy it was something so minor, but that dang buzzer and flashing light is something I hope to never see again in this truck.
    MJoeP and pickeledpigsfeet like this.
  25. Jan 17, 2023 at 5:00 PM
    ThatGuy246
    ThatGuy246 New Member
    2004 Tundra
    Yours is a bit of an overreaction don't you think?. Even if someone does research they can can still get a shitty truck. My 04 tundra, a great truck 230k miles and still going. My 2019 Tundra not so good. 55k miles and problems
  26. Jan 17, 2023 at 5:01 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    3y later....I still stand by my post.
    Joe333x likes this.
  27. Jan 17, 2023 at 5:03 PM
    Joe333x
    Joe333x Member
    Boston
    :rofl: your response time was amazing. Does anyone look at dates before posting replies?
  28. Jan 17, 2023 at 5:07 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I had to look up the post he quoted me on as I didn't remember posting anything like that recently.
    Saw it was 2022, thought that was 2 years ago, turns out it's 3 now.
  29. Jan 17, 2023 at 5:14 PM
    ThatGuy246
    2004 Tundra
    I'm glad it was minor. My 2019 did the same thing a few days ago. Flashing yellow triangle, buzzer, no message with it just flashing light and buzzer. Someone on here suggested a hood latch. I will take to dealer it maybe the same issue. It seems odd that a hood latch would cause a warning light.
  30. Jan 17, 2023 at 5:34 PM
    ThatGuy246
    2004 Tundra
    I'm not surprised
