Marvel Mystery Oil
Discussion in 'General Tundra Discussion' started by T-Guy69, Nov 11, 2024.
  1. Nov 11, 2024 at 4:37 AM
    T-Guy69
    T-Guy69 [OP] New Member
    Long Island
    Black 2020 Tundra SR5
    Marvel Mystery Oil is 70% Naphthenic Hydrocarbons. 29% Mineral Spirits. It can be used as a gas for its upper cylinder lube than it is a cleaner. I have used it in my 1969 Chevrolet that doesn’t have a catalytic converter and my old 2002 two stroke Mercury.
    I have worries about adding it to my 2020 Tundra. It might flooded the catalytic converter and O2 sensors with oil/lubricant.
    In the old days with lower catalyst efficiency standards (pre-2002) there would be no issue. But today’s catalytic converters are held to a higher efficiency (+-90%). I use tier one gas.
    Thoughts?
  2. Nov 11, 2024 at 4:54 AM
    Retired...finally
    It's commonly added to Avgas but none of us will ever admit to it.
  3. Nov 11, 2024 at 5:12 AM
    Don’t use it. I’ve never used that stuff and all of my cars have lasted 100s of thousands of miles anyway. It’s unnecessary. It’s practically snake oil.
  4. Nov 11, 2024 at 5:13 AM
    2mchfun
    What is your goal? Cleaning or lubing? Maybe both? Have you used Berryman's B 12 for cleaning? Good stuff. If your plan is to clean rings with directly pouring it in the plug holes, you can remove the converters for a bit.
  5. Nov 11, 2024 at 5:33 AM
    A fellow Jarhead was a Fueler. MCAS Iwakuni. They had 50 gallon drums of MO. Definitely common to add to AVGAS. Definitely not snake oil. It served its purpose in this case.
    bulldog93 likes this.
  6. Nov 11, 2024 at 5:40 AM
  7. Nov 11, 2024 at 5:41 AM
    What is the perceived benefit in adding it to a vehicle (not an airplane) that has been proven to last 100s of thousands of miles with only the recommended maintenance? Whatever benefit is obviously not necessary for our application, which lands it in the unnecessary, and potentially just snake oil for our trucks.
  8. Nov 11, 2024 at 6:13 AM
    Tundra family
    Tundra family New Member
    It's good in the gas if you going to put a vehicle in storage. That's the only time I'll use it.
    bulldog93 and KNABORES[QUOTED] like this.
  9. Nov 11, 2024 at 7:29 AM
    Retired...finally
    If adding anything to gasoline helped an engine perform better, don't you think the refineries would be adding it?
  10. Nov 11, 2024 at 7:31 AM
    Tundra family
    Not if it meant they could sell you more gas by leaving it out. Just sayin.
  11. Nov 11, 2024 at 7:34 AM
    Retired...finally
    That's true. Has MMO ever been shown or thought to increases MPG. I....Or some dude at the airport...uses it to keep the valves from sticking but I....I mean he, never recorded any lower fuel consumption.
    Tundra family[QUOTED] likes this.
  12. Nov 11, 2024 at 8:17 AM
    Ericsopa
    Ericsopa Old man and the sea
    No.
  13. Nov 11, 2024 at 11:46 AM
    T-Guy69
    Long Island
    Unfortunately, that is what we have to deal with….opinions without facts.
    I started using it when my outboard mechanic started using his “secret mixture” when winterizing my outboard. He would not tell me all the ingredients. But MMO was one of the ingredients. I did notice the outboard started easier in the spring when he winterized my outboard than when I did. So, I started using it in my Chevy too when putting it away for the winter. But neither the Chevy nor the outboard have catalytic converters.
