Marker lights of TRD Pro Grill randomly going on
Discussion in '3rd Gen Tundras (2022+)' started by JLTundy, Mar 18, 2025.
  1. Mar 18, 2025 at 5:40 PM
    JLTundy
    JLTundy [OP] New Member
    2024 Lunar Rock Tundra Limited CrewMax 4x4
    TRD Pro Fox Suspension 34” Wrangler Duratrac 15% tint JB4 Tuner Pedal Commander AFE Vulcan Exhaust System AFE Momentum Cold Air Intake TRD Pro Grille w/light bar and marker lights Diode Dynamics Stage Series C1 Sport light kit
    What’s up,
    I had some aftermarket marker lights installed on my 24’ Tundra limited with an TRD Pro grill. The market lights will randomly go on sometimes. Typically the lights only run when the truck is on. I believe the market lights are wired with the running day lights. Anybody got any suggestions? Thanks
  2. Mar 18, 2025 at 5:46 PM
    lapoolboy
    lapoolboy New Member
    Who wired them?
  3. Mar 19, 2025 at 2:16 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    What did you tap, and/or fuse to?
  4. Mar 20, 2025 at 10:33 AM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    If it’s a fuse tap, there are some fuses that intermittently come on throughout the day, whether the truck is on or not. I tapped my drls to a fuse that did that, relocated to a different fuse and haven’t had them come on without the truck on, since.
  5. Mar 20, 2025 at 10:53 AM
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    OP asks for suggestions and now gone
  6. Mar 20, 2025 at 11:43 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    They didn't expect to have to answer questions.....just tell me the answer dammit!!
    ScottieBones and oddhours like this.
  7. Mar 20, 2025 at 12:18 PM
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    Wiring is typically fairly easy. Using a digital multi meter provides your answer. If you verified readings using proper equipment, then the component is faulty.
    Ever see those menacing Tacos and 4R measuring under 80” wide with aftermarket DOT lights that flicker?
    chrisgibbs707 and lapoolboy like this.
  8. Mar 22, 2025 at 11:07 PM
    JLTundy
    Appreciate the responses
  9. Mar 30, 2025 at 9:37 AM
    JLTundy
    After looking through some old threads like I should have in the first place, I came to the conclusion to move the wiring harness from the driver’s side fuse box to an open ENG IGR fuse slot in the passenger fuse box. Just had to extend the wiring. This seems to be working.
