Map Light Install Issue
Discussion in 'Lighting' started by Tiger Tundra, Aug 31, 2015.
  1. Aug 31, 2015 at 7:37 PM
    Tiger Tundra
    Tiger Tundra [OP] New Member
    2015 Tundra TSS Off Road
    So I got my LED bulbs in today.. great, right?
    Well, i think I've messed up. First, I got it installed and it came on fine (driver's side). But then I realized the bulb was too wide (the glass part) and the silver reflector inside wouldn't fit around it. I apparently pushed too hard and the connector moved up inside. I was able to pull them back down, but now no bulb (factory or LED) will work in it.
    1) What have I done and how can i fix it?
    2) If i do get it working again, can I just leave the reflector out?
  2. Aug 31, 2015 at 7:43 PM
    Any photos to help show this?
  3. Aug 31, 2015 at 7:49 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I keep blowing a fuse with mine:annoyed:
  4. Aug 31, 2015 at 10:32 PM
    Tiger Tundra
    @Sean266 i can't figure out pics but I have a couple posted at tundratalk.net. Posted a similar forum over there same time tonight.
    And checked the fuse it's good
  5. Sep 1, 2015 at 5:34 AM
    You may have separated/widened the connector. I did the same thing. Used a small jewellers' screwdriver to re-shape/re-position the connector to get a good contact again. A definite PITA.
  6. Sep 1, 2015 at 8:36 AM
    Tiger Tundra
    Gonna give it a go today, this changing interior bulbs thing got out of hand quick
  7. Sep 1, 2015 at 8:36 AM
    Tiger Tundra
  8. Sep 1, 2015 at 8:37 AM
    Ouch. You can try to fix it, but it may need a whole new inside piece you can get from @TRDSparks
  9. Sep 1, 2015 at 10:32 AM
    Tiger Tundra
    Finally got them all installed, much easier in the light and after knowing what I was doing. The one I originally messed up had to be reshaped (connectors) with some tiny pliers and it's not holding real tight but working for now.
    Thanks for the help!!
    T-Rex266 and Black Wolf like this.
  10. Sep 1, 2015 at 10:55 AM
    I was able to get connectors back to normal. The metal was very pliable. (Kind of cheesy actually). That's why it was so easy to fix.
  11. Sep 11, 2015 at 9:58 AM
    Tiger Tundra
    Everything's been great with the lights I'll upload a pic tonight. SO BRIGHT. Best low $ upgrade possible.
  12. Sep 11, 2015 at 9:58 AM
    Tiger Tundra
    Did blow a fuse randomly though, had to replace a 7.5
