Manual trans swap and SAS
Discussion in '1st Gen Tundras (2000-2006)' started by hurlz442, Jun 3, 2019.
  1. Jun 3, 2019 at 7:36 PM
    hurlz442
    hurlz442 [OP] New Member
    nathan
    kelowna
    2006 toyota tundra
    lift, 33/75r16 NItto trail grapplers MT
    Just wondering how big of a worm hole this would be to go down. I have to rebuild/swap the current engine she made it to 485xxxkm and was barely running when I flipped the truck (pretty proud of her) would like to tare everything outta the front end and replace the t-case, manual transmission throw an axle in the front and put a flat deck on her because the box is messed up pretty good. Id like to know if anyone else has done a SAS on a 06 if so some info for parts would be very helpful same goes if anyones done a manual trans swap.
    ethan1911 likes this.
  2. Jun 3, 2019 at 7:42 PM
    Casper421
    In the woods
    06 DC
  3. Jun 4, 2019 at 3:36 AM
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    If your good with fab work I say go for it. The biggest hurdle you’ll come across is every part for a SAS has to homemade or modified. How tall do you want it to be? If your going to stay in the 33”-35” range. You’ll need to do a lot more frame modifications than if you were going to make it set like a monster truck.
