Manual Tailgate Lock?
Discussion in 'General Tundra Discussion' started by Hishers55, Nov 26, 2022.
  1. Nov 26, 2022 at 8:07 PM
    Hishers55
    Hishers55 [OP] New Member
    I have a 2012 Tundra. It did not come with a tailgate lock. Is there a manual tailgate lock (with a key) available to replace the current tailgate latch?
  2. Nov 26, 2022 at 8:18 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Does it have the camera?
  3. Nov 26, 2022 at 8:27 PM
    Hishers55
  4. Nov 28, 2022 at 8:04 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Didn't know that was even a thing.
    So there isn't even a hole to insert a key??
    If yours doesn't, I imagine any latch mechanism from an SR5 trim and up will have a lockable latch
  5. Nov 28, 2022 at 8:17 AM
    Hishers55
    Thank you.
  6. Nov 29, 2022 at 6:49 AM
    COTundie
    Trey
    Pretty things
    Now that I think about it, you would probably need the handle mechanism along with a tailgate specific (this lock cylinder only uses like half the key) lock cylinder, with assorted tumblers/wafers to match with your existing key.
    With all of this in mind, if you happen to have keyless entry, it would probably be easier to install an aftermarket auto-locks retrofit to lock/unlock with the rest of the doors. Might even be cheaper to upgrade the whole truck to aftermarket keyless than to upgrade just the handle with Toyota parts.
