Manual locking front differential actuator
Discussion in '1st Gen Tundras (2000-2006)' started by KY2002AC, Jan 17, 2024.
  1. Jan 17, 2024 at 9:32 PM
    KY2002AC
    KY2002AC [OP] New Member
    Ryan
    2002 AC 4.7 4x4 Tundra
    Rough Country lift, TRD Pro wheels, Firestone X/T tires
    I am interested in fabricating a manual locking front differential actuator. Has anyone done this?
  2. Jan 18, 2024 at 9:15 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I’m not sure if anyone on here has done that, but I believe it’s possible.
    This guy on youtube has a 1GT that he really uses, and he wired his ADD to a switch on the dash. There might be some differences as his truck has a V6 and is stick shift, so he’s got a physical level for 4WD.
    https://youtu.be/rnS4bgFhWCM?si=8v4WOekF-uUMDTMK
    Why would you want a manual front actuator? If you want to eliminate the possibility of electrical issues, you can remove the ADD (Automatic Disconnecting Differential) actuator and use a hose clamp to keep the front diff always engaged.
    The Black Mamba likes this.
  3. Jan 18, 2024 at 10:21 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    This is my plan for the 4wd conversion to be used with a j shift t-case (way the hell down the road, btw :rofl:)
    FiatRunner[QUOTED] likes this.
  4. Jan 18, 2024 at 10:24 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Also, I read somewhere on here where a guy used T4R manual locking hubs with a permanently engaged ADD. Could be an option for you. Search that one out though.
    Jack McCarthy and FiatRunner like this.
