Making a E-85 only truck
Discussion in 'New Member Introductions' started by Richard440, May 30, 2022.
  1. May 30, 2022 at 1:28 PM
    Richard440
    Richard440 [OP] New Member
    Richard
    14crew5.7
    13:1 pistons, ported heads
    Installed 425 pump with 750 cc injectors, new lines and pressure regulator. Need to tune the ecm. The AFR has learned from 10:1 to14.1:1 in 10 warmups cycles. E-85 I heard takes 12.6:1 AFR. Hp. Tuners gave me a stock tune to change. Even I see big Preformance problems with the stock tune. 10 sec. delay on PE.
  2. May 30, 2022 at 2:14 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Are you asking a question? It sounds like an interesting project.
  3. May 30, 2022 at 2:30 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
  4. May 30, 2022 at 3:49 PM
    Richard440
    Richard
    14crew5.7
    I think I have most of the problems solved. I want a fuel filter before the injector rails. One day I will get bad gas and I don’t want it to make big problems
