Make this truck last
Discussion in '1st Gen Tundras (2000-2006)' started by Dale86, Feb 27, 2020.
  1. Feb 27, 2020 at 5:35 AM
    Dale86
    Dale86 [OP] New Member
    2005 Toyota Tundra V8 Crew Cab 2wd
    None
    2005 Tundra DC 2wd w/ 220k
    Just replaced the timing belt and water pump. I’m trying to get this rig to last me another 100k+ if possible. What preventative maintenance schedule do y’all recommend and what products should I be using? What other parts should I be looking to replace at this point? Especially suspension/steering parts? What mileage intervals are y’all doing your different maintenance and replacement parts at?
  2. Feb 27, 2020 at 5:38 AM
    Professional Hand Model
    Hand Protectors
  3. Feb 27, 2020 at 5:58 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I can't see any reason why you can't do another 100k. We've had members here with over 500K miles. The next think I would focus on is fluid changes. Do you know if the transmission has ever been serviced?
  4. Feb 27, 2020 at 8:55 AM
    Dale86
    None
    Drain and fills only on transmission.
    What about suspension parts at this point? What should I replace or expect to replace at this point?
    My truck is never off-road and spends most of its time on the highway.
  5. Feb 27, 2020 at 9:39 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Lower ball joints, only go with OEM.
    FrenchToasty likes this.
  6. Feb 27, 2020 at 10:42 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That's good. I would also do the rear diff, coolant, brake fluid, power steering. Sounds like you've already been on top of the maintenance. But yes, to answer your question you're likely due for suspension work too. You can get the front end off the ground and check for play in the ball joints and tie rods. I had some side to side play that went away after replacing the outer tie rods. New coilovers up front and shocks in the rear might be a good idea too.
    Tundra2 likes this.
  7. Feb 27, 2020 at 12:52 PM
    Aerindel
    Aerindel New Member
    Montana
    320k myself. Nothing extraordinary. Timing belt when needed and other stuff as it breaks. Radiator is a good one. Mine cracked and leaked before it had other problems but they can potentially fail and mix coolant and transmission fluid.
    Being 2WD I don't think you have grease-able U joints but that is a good thing to do, otherwise expect to replace a few.
    Keep your parking brake adjusted and in good condition as it is what keeps your rear brakes and by extension, your entire braking system in good order.
    Tundra2 likes this.
  8. Feb 27, 2020 at 1:40 PM
    SouthPaw
    2000 Limited 4x4 AC
    Oh, breather mod for rear axle.
