Make this truck better off road?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rocko9999, Jan 11, 2022.
  1. Jan 11, 2022 at 12:47 PM
    Rocko9999
    Rocko9999 [OP] New Member
    Anyone have any tips for making my truck do a little better off road-particularly sand?
    2014 DC 6.5' bed 2WD. Has 275/65R18 Pathfinder AT tires. Seems to do ok on hard pack but the second I hit a even just a little soft sand it loses it. Not looking to go off hardcore offroad-just be able to not get stuck on sandier jeep roads. Do I need to air down tires even less than 25psi? Add weight to bed?
  2. Jan 11, 2022 at 1:09 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Wider tires, rear locker, remove 1500lbs from the front :rofl:
  3. Jan 11, 2022 at 1:12 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yup. Tires will probably be your best bang for the buck.
    you could probably get away with down to 15psi without headlocks but you still run the risk of popping a bead off.
    Rocko9999[OP] likes this.
  4. Jan 11, 2022 at 1:16 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Air down on sand to 18=20lbs, use 4wd. Larger tires help with offroad. Even stock, you can fit 275/70-18 or 285/70-18 on a stock truck with stock wheels, no issues.
    alb1k likes this.
  5. Jan 11, 2022 at 1:21 PM
    Rocko9999
    Exactly. It's like a sand plow-just nose dives down with no traction to do anything about it.
  6. Jan 11, 2022 at 1:29 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    You need to air down WAY more than 25psi. I start at about 12psi, and if shit gets hairy drop it lower. Sand is all about tire pressure, and being in the high teens or 20s I would not even consider being aired down at all. 4wd would obviously help a lot too, but regardless you need to drop pressure a lot more.
  7. Jan 11, 2022 at 1:45 PM
    CTundraForMe
    CTundraForMe New Member
    I think op says it's a 2WD truck?
    Seems to me a 2WD truck is going to have a hard time in sand.
    Terndrerrr and 1UP like this.
  8. Jan 11, 2022 at 1:50 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Weight in the back, low low tire pressure. Avoid loose sand at all cost, never go heavy on the gas. Slow and steady, can’t tell you how many 2wds I’ve pulled out of the beaches here.
  9. Jan 11, 2022 at 2:28 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Sell it and get a 4wd
  10. Jan 11, 2022 at 2:59 PM
    Amoeba20
    Amoeba20 New Member
    Las Vegas, NV
    2007 Green Tundra TRD 2wd DC
    ToyTec Boss kit (3" front, 1.5" shackle) 35" Yokohama Geolander X-AT, Alpha Equip Delta wheels 17x8.5 (+35mm) BAMF 6" exhaust Nitro 5.29 gears and Powertrax Grip Pro diff
    Having plenty of actual sand/dune driving in a 2wd truck myself, I completely agree with Snivilous. I had a long travel 1st gen tundra (2wd) on 35s with a detroit true-trac, 12-10 psi in the front, 10-8 psi in the rear, and that got me all over the place in the dunes. I never blew a bead either, as long as you don't make sharp cuts/turns you'll be fine.
    Having a larger tire does help to increase your footprint when you air down. A limited slip rear end helps a lot too. My 07 tundra (2wd) has 35s on 17-inch wheels, a mechanical limited slip, and 3-inch lift. Some extra weight in the bed would help, but I do just fine without anything extra besides the spare tire. I have little fear of sand in the truck.
    For sand: air down to 12 or less psi, turn off all your nannies, when you do stop only do it on level ground or pointed downhill, momentum is your friend, look ahead to visualize the best lines to take, take off slowly from a standstill.
    W3agle, alb1k, Terndrerrr and 4 others like this.
  11. Jan 12, 2022 at 8:56 AM
    Rocko9999
    Thank you. I will have to try airing down quite a bit more. Does the traction control on my 14' make things worse in sand? From what I read it just adds breaking to the tire losing traction.
  12. Jan 12, 2022 at 9:02 AM
    Rocko9999
    Thanks. The desert I frequent often has decent jeep roads but these intersect sandy washes often-that can be 40 yards long or 1 mile long. Just looking for best strategy to get through these when encounter them. Never had a problem in my old 2wd Expedition on these roads with street tires-good weight distribution.
  13. Jan 12, 2022 at 9:03 AM
    Rocko9999
    Thank you. Still learning.
  14. Jan 12, 2022 at 10:00 PM
    TTund16
    TTund16 New Member
    Does a 2WD trucks have the ALS button like the 4WD?
    You would think it should since its not really a mechanical feature or upgrade since its just computer brake control ...
  15. Jan 12, 2022 at 10:44 PM
    Tires/pressure and Mechanical LS. Truck would be pretty good on the sand with limits.
  16. Jan 13, 2022 at 11:49 AM
    Rocko9999
    I think their traction control system on this year is "Brake Actuated Limited Slip Differential" for whatever that is worth.
    TTund16[QUOTED] likes this.
  17. Jan 13, 2022 at 11:59 AM
    2mchfun
    Tie on about 125,000 helium filled mylar balloons.
    Hbjeff likes this.
  18. Jan 13, 2022 at 6:13 PM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    As for those "sandier jeep roads," cheat by trying to stay in hard sand rather than soft sand. Beyond that, you're obviously limited by the lack of 4wd. Really wide tires would help, but I have no advice on that. To be honest, I'd just avoid soft sand, and keep a winch & traction pads handy.
