Maintenance required light
Discussion in '1st Gen Tundras (2000-2006)' started by Hi06silver, Feb 4, 2023.
  1. Feb 4, 2023 at 9:35 AM
    Hi06silver
    Hi06silver [OP] Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Does the maintenance required light reset when the battery is disconnected?
    I know how to reset it but I'm as for O/C intervals rely on that if I forget to right down the mileage.
    dirtnsmores likes this.
  2. Feb 4, 2023 at 9:47 AM
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    No it does not reset with battery disconnect
    Hi06silver[OP] and FrenchToasty like this.
  3. Feb 4, 2023 at 10:52 AM
    It depends on what type of light it is.
    Yes, it absolutely will reset on codes generated from readiness. Just leave the battery off 10 minutes.
    For persistent and safety systems (on most cars at least) it won't.
  4. Feb 5, 2023 at 3:33 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    This is how I do it on my 08 4runner...probably the same for your truck:
    How to Reset a Toyota Maintenance Light
    1. Put your key in the ignition and turn it to position one, the position just before starting the car.
    2. Push and hold the trip meter reset button on the dashboard, then turn your key to position two.
    3. Continue holding the odometer button for 10 seconds.
  5. Feb 5, 2023 at 7:36 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Just the distance traveled since last oil change. I ask because when the alternator was changed it was obviously disconnected for some time. I guess I'll just change the oil here before to long if I can't find the mileage I changed it last.
  6. Feb 5, 2023 at 7:51 AM
    Oh I was confusing "maintenance required" with "check engine", because some check engine lights have "MAINT" under them instead of "CHECK". My comment above is purely for when the money light comes on. When my oil maint light comes on, I just reset it. I don't use the internal 5000 mile counter, I drive too few miles to rely on it.
    Purely my misunderstanding.
    Speaking of which, my wife's oil light is on. I need to change her oil soon. Haven't done the 2020 Highlander yet, I don't even see the damn filter, and there's a huge wooly mat covering the underside of the vehicle. Should be a blast, I'm sure.
  7. Feb 5, 2023 at 9:25 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    This is the procedure but before you start make sure your guage cluster is in the odometer screen, not trip. Turn off the truck and when you hold the button down and turn the key to accessory if you did the reset right you will see a line of 6 or so dashes. Once all the dashes have 'counted down' you will have successfully reset the oil change light.
    EmergencyMaximum likes this.
  8. Sep 16, 2023 at 9:21 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    This worked perfectly for me thank you
  9. Sep 16, 2023 at 9:25 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    The whoosey whatnow?
    Never saw one on my 2002. Must be no maintenance required. o_O
    JasonC., dirtnsmores and FrenchToasty like this.
  10. Sep 16, 2023 at 9:26 PM
    dirtnsmores
    Southern CA
    It goes off every 5000 mi, it just means you're due for an oil change. And typically the mechanic resets it, but sometimes they forget
