Maintenance Questions for 2014 Tundra SR5
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundrabubba, Sep 13, 2023.
  1. Sep 13, 2023 at 6:49 PM
    tundrabubba
    tundrabubba [OP] New Member
    Andrew
    I have a couple of maintenance questions! I have a 2014 Tundra SR5;
    I need to replace the back rotors/brake pads, change out the spark plugs, transmission fluid and 4x4 diff service.
    for the brakes/rotors - is there a special/upgraded brand you could recommend ?
    spark plugs - ^ same question; or stick with factory (what is factory)
    for the transmission fluid/4x4 diff - any suggestions there? or just stick with factory
    TIA
  2. Sep 13, 2023 at 7:47 PM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    Factory rotors, factory denso spark plugs (or ngk), factory ATF. The diff fluids you can use Red Line's comparable type.
  3. Sep 13, 2023 at 8:01 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Personally i do OEM on all of those.
    Bammer likes this.
  4. Sep 14, 2023 at 3:54 AM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    100% OEM for everything listed above :thumbsup:
