Maintenance question?
Discussion in '2nd Gen Tundras (2007-2013)' started by SJP2012TUNDRA, Nov 2, 2023.
  1. Nov 2, 2023 at 11:41 AM
    SJP2012TUNDRA
    SJP2012TUNDRA [OP] New Member
    2012 Tundra TRD 4x4 double cab
    3” Toytec lift ( bilstien shocks, springs and spacer ) 285/70R18 Toyo AT’s
    Good afternoon, I’m a new Tundra guy. Before posted I looked around the forums for the needed information.
    I recently purchased a 2012 Tundra TRD 4x4 from a friend. It’s got approximately 105,000 miles on it and been well take care of
    This is a two part question,
    1)
    I’m looking to do the following services.
    Cooling system service
    Fluid replacement front / rear differential.
    Transmission service
    Respect spark plugs
    Replace radiator hoses
    A local ( Southern California) Toyota dealership quoted me $2600 for the above, a local mechanic quoted me $1300.
    2) what other services should I perform on this truck?
    AlexJD likes this.
  2. Nov 2, 2023 at 11:56 AM
    gnatehack
    gnatehack New Member
    Middle of Minnesota
    13 SR5 5.7 4x4 Bench
    Up to date maintenance
    You should do all that yourself; cut that expenditure in half, at least, again.
    Get Denso Iridium plugs. Lube the driveshaft. Change transfer case fluid. Check the spare. Check the water pump.
    None of this is hard. It's all been done before. Drive up to MN and I'll help you out!
    AlexJD likes this.
  3. Nov 2, 2023 at 12:08 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Check timing belt.
  4. Nov 2, 2023 at 12:13 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    you can do all that yourself for probably 1/3 of the mechanics price.
    AlexJD likes this.
  5. Nov 2, 2023 at 12:17 PM
    gnatehack
    Middle of Minnesota
    The pic shows a 5.7.
    No timing belt.
    grave, PhotoNerd and Tileguy like this.
  6. Nov 2, 2023 at 12:46 PM
    SJP2012TUNDRA
    I know I can save money doing it myself however time is my problem. I was asking to see if $1300 is a fair price?
  7. Nov 2, 2023 at 1:01 PM
    MadMaxCanon
    It wouldnt be for me, but compared to the dealer it is. It all comes down to how much you value your time really.
    Bprose likes this.
  8. Nov 2, 2023 at 1:23 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Bigger question is do you trust the mechanics?
  9. Nov 2, 2023 at 2:15 PM
    SJP2012TUNDRA
    Yes, he’s worked on other cars I own before.
  10. Nov 4, 2023 at 2:57 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    I wouldn’t worry about radiator hoses at 100k miles get the brake pads and rotors checked
  11. Nov 4, 2023 at 2:59 PM
    Retired...finally
    Replace brake fluid if it's the least bit dark.
