Maintenance light on & 4LO flashing ?
Discussion in 'Sequoia Builds' started by Sequoiar, Sep 13, 2020.
  1. Sep 13, 2020 at 4:29 PM
    Sequoiar
    Sequoiar [OP] New Member
    2014 Sequoia SR5 w/ 67K mi
    won't go into 4wd
    no other issues I can sense, likely going to shop for diagnostics in next few days
    any ideas?
  2. Sep 13, 2020 at 4:53 PM
    timsp8
    NY
    No CEL? This might help. Says just 4 Lo flashing is MAF sensor.
  3. Sep 13, 2020 at 5:26 PM
    Sequoiar
    the maintenance light is on (not blinking) is this the CEL?
  4. Sep 13, 2020 at 5:38 PM
    timsp8
    NY
    No. Maintenance light is for oil changes and is set to come on at predetermined mileage, like every 5k. Are you sure it’s the maintenance light and not a CEL?
    If it’s a CEL, get someone to read it and figure out the code. Auto parts stores will usually read them for free.
  5. Sep 14, 2020 at 8:25 AM
    Sequoiar
    Sweet chart, thanks.
    The maintenance light next to the oil icon is illuminated (not blinking).
    This morn the 4lo light is not flashing and the Sequoia will go into 4x4?
    Yesterday I swapped for a set of hwy wheels/tires, perhaps this triggered something?
    Iron1 likes this.
  6. Sep 17, 2020 at 6:41 PM
    Sequoiar
    nothing showed on scan.. appears to have resolved
  7. Sep 17, 2020 at 9:24 PM
    Iron1
    Iron1 New Member
    Miami
    2008 sequoia limited
    Icon 2.5 suspension remote reservoir front,belstein shocks and springs with 2ich spacer in the rear,18inch rhino armory ,35 in Nitto grapplers.
    That’s definitely what triggered it, get ready for vsc traction control light to come on next smh
  8. Sep 18, 2020 at 10:49 AM
    Sequoiar
  9. Sep 18, 2020 at 4:29 PM
    Iron1
    Iron1 New Member
    Miami
    You’re going to be fine,it won’t effect the way your truck drives.there is a video on you tube on how to chemie the yawrate senior in case you get the vsc light.that should fix that problem
