Maintenance advise
Discussion in '2.5 Gen Tundras (2014-2021)' started by Netmonkey, Jul 7, 2021.
  1. Jul 7, 2021 at 6:31 AM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    Hey guys,
    So I have always have my truck serviced at a local Toyota dealership. This dealership is one of the good ones and they have earned my trust over the years. However, at the last service, the service report says that the truck needs a fuel system service, a power steering fluid exchange, and a brake fluid exchange. To me, this feels like the dealer is trying to get you to pay for services just so that they can make more money. They are not pushing me to do it; they just have mentioned it.
    I checked the manual and I could not find any entries for these 3 services; even under the extreme usage section. The truck has 60k miles on it, I have towed twice with it, and I am not experiencing any power, steering, or braking issues.
    Is there any point (mileage or years) at which those systems need these preventative services?
    Thanks,
    Oey12 likes this.
  2. Jul 7, 2021 at 6:43 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    A lot of times these just “pop up” on the service list regardless of any actual need to do the service based on inspection. I’d follow the owners manual recommendation. Might also ask the dealer why they think it’s needed. If they’re calling it “preventative” ask why they are recommending it contrary to what the maintenance schedule in the manual says.
    I stopped taking my cars to dealers. They always want to replace the cabin air filter for like $75 and you can do it in 2 minutes with a $10 filter!
    Netmonkey[OP] likes this.
  3. Jul 7, 2021 at 7:20 AM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    From my perspective as a mechanic for many years, it is good to do these services every few years. 50-60K is a good mark for all 3 of those.
    1. Fuel system service - cleans throttle body, manifold, and fuel system (specifically injectors) of carbon build up. Also relearns base idle. Excessive carbon buildup can cause poor performance and misfires for various reasons.
    2. Power Steering Fluid - Severely degraded fluid can result in loss of steering performance and also degrades seals causing leaks.
    3. Brake Fluid - Brake fluid absorbs water and is subject to high temperatures. Fluid with high water content can cause brake fade as well as degrading of seals. Very important to maintain brake fluid when you do a lot of towing and/or haul heavy loads.
    Over maintaining your vehicle is not a bad thing. Just make sure to use the proper fluids and follow procedures.
  4. Jul 7, 2021 at 7:37 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Another thing to think about is the fact that there are different environments to take into consideration. Brake fluid for example, absorbs condensation and may deteriorate in some areas faster than others. Different gasoline additives required in some areas may create more fuel system deposits. City driving creates more power steering fluid heat and system wear. I also think 60k is a good point for these services. Never do a transmission flush...ever.......filter and fluid change only at 100k-120k.
    15whtrd, Oey12 and Netmonkey[OP] like this.
  5. Jul 7, 2021 at 7:40 AM
    trails-end
    trails-end New Member
    NWGA
    2021 Tundra SR5 4x4 crewmax trail white
    TRD antisway bars front and rear.
    Can you elaborate on that transmission flush notice?
  6. Jul 7, 2021 at 7:40 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    What do you mean by filter and fluid change only on transmission?
  7. Jul 7, 2021 at 7:44 AM
    timsp8
    NY
  8. Jul 7, 2021 at 7:49 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I don’t know if there is a schedule for those items or not but years ago I had the dealership perform those services on a 6 year old Tacoma. There were zero problems with the trucks brakes, engine, or steering. However after the services everything did feel smoother. So personally I am an advocate of doing those services every five years. All fluids break down and if your into your Tundra for the long haul, I would do it…it’s not dealership BS. Prices now…a whole different discussion.
    Netmonkey[QUOTED][OP] likes this.
  9. Jul 7, 2021 at 7:58 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I just took my truck for service last Friday and i got all the same thing also added was a balance and alignment.
    I declined the service, for the mean time and my truck has 60k on it.
  10. Jul 7, 2021 at 8:07 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Don't waste your money on the fuel system service or power system fluid service. The fuel system services are big time profit centers for dealers. Our Tundras have port injected engines, and the gasoline we use has additives in place that keep things clean. If you want, buy a couple bottles of Techron Fuel System Cleaner at Walmart or Advance (buy 1, get 1 this month) and add to your next tank of gas.
    It probably is a good idea to replace the brake fluid every few years as it absorbs water.
    Saltyhero13, Buckaroo and Ely010606 like this.
  11. Jul 7, 2021 at 9:11 AM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    For the most part, when using Top Tier detergent gas, you’re right about the fuel system. It does not, however, cover the throttle body, which is still subject to build up via crankcase ventilation. Dirty throttle bodies will increase stress on the internal TB motor, reduce responsiveness, efficiency, and in worse cases, cause sticking, which can trigger CELs for TP sensors.
    vipgs3 likes this.
  12. Jul 7, 2021 at 11:49 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I also do not do ATF flushes on vehicles - I always do a drain and refill. I am careful, particularly for higher mileage vehicles, as I don't want to flush any build-up into the small hydraulic passages that control trans operation. A noted problem with Honda transmissions. For the Tundra, I recently completed this and replaced the filter at 43,000 miles as I tow a heavy travel trailer. I will do this again in another 30,000 miles. Had previously changed the fluid in the front & back differentials and the transfer case at 30,000 miles.
